What permissions to i need to allow to let a user create edit and delete call forwarding or follow me
			I’m basicity trying to allow a agent to transfer a call group to a alternative number and I would also like it if they can dial a number from the handset to set up the call divertIs that user assigned to any extensions?
And would this also divert calls from a ring group?Yeh *720800111111, or just enable (*72), disable(*73) or toggle(*74). You can modify the request_id=false line to set it to true, so anyone as long as you have the voicemail pin can enable a call forward.
