Our setup:
Someone calls in on a number +1 (555) 555-0826, which gets forwarded to an answering service +1 (555) 555-6211. I have a dial plan set-up that when someone calls in it forwards to 982615555556211. The dial plan strips the prefix "9826", and sets the 'effective_caller_id_name" and "effective_caller_id_number" to 15555550826. This was the answering service knows what company the person is calling. Everything works until someone with a anonymous, or blocked caller ID, calls. When they call the Caller ID is blocked when the call is forwarded. I've tried using the "action unset sip_h_Privacy", "action unset sip_h_Privacy=id", "action unset sip_h_Privacy=none", "action set sip_h_Privacy=id", and "action set sip_h_Privacy=none". I've also tried using the "outbound_caller_id_name" and "outbound_caller_id_number", but nothing seems to work to turn off the blocked caller id.
Tag Type Data Break Inline Group Order Enabled Delete
condition ${user_exists} false 0 10 true
condition destination_number ^9826(\d{11})$ 0 20 true
action set sip_h_accountcode=${accountcode} 0 30 true
action export call_direction=outbound true 0 40 true
action unset call_timeout 0 50 true
action set hangup_after_bridge=true 0 60 true
action set effective_caller_id_name=15555550826 0 70 true
action set effective_caller_id_number=15555550826 0 80 true
action set inherit_codec=true 0 90 true
action set ignore_display_updates=true 0 100 true
action set callee_id_number=$1 0 110 true
action set continue_on_fail=1,2,3,6,18,21,27,28,31,34,38,41,42,44,58,88,111,403,501,602,607,809 0 120 true
action unset sip_h_Privacy=none 0 121 true
action set outbound_caller_id_name=15555550826 0 122 true
action set outbound_caller_id_number=15555550826 0 123 true
action set outbound_prefix=9826 0 130 true
action bridge sofia/gateway/Telnyx/$1 0 140 true
