Call Group Pickup / Intercept
dcitelecom
174
I can't get call pickup to work in a group. I created a call group "ABC" with 4 extensions and want to pick up incoming calls to any extensions not answered on another extension. I tried *8 and ** but it's not working. Can anyone help? Thanks.
you need to make sure the path to the FreeSWITCH database is correct
I am not sure I understand. This system has been running without issues for 2 years. Surely database access is defined correctly. I only have a problem with the Call Group Pickup as explained above.
Just check
etc/fusionpbx/config.conf
And see if settings are good if using default or RAM drive
Just check
#database
database.1.type = pgsql
database.1.host = 127.0.0.1
database.1.port = 5432
database.1.sslmode=prefer
#switch settings
switch.conf.dir = /etc/freeswitch
switch.sounds.dir = /usr/share/freeswitch/sounds
switch.database.dir = /var/lib/freeswitch/db
switch.recordings.dir = /var/lib/freeswitch/recordings
switch.storage.dir = /var/lib/freeswitch/storage
switch.voicemail.dir = /var/lib/freeswitch/storage/voicemail
switch.scripts.dir = /usr/share/freeswitch/scripts
#switch xml handler
xml_handler.fs_path = false
xml_handler.reg_as_number_alias = false
xml_handler.number_as_presence_id = true
Thanks for trying to help but I don't know where to find these values. There is no DSN switch variable in fusionpbx.
The answer to the question depends on the version of FusionPBX. Please share your version.
Note: The DSN is not in FusionPBX by default. It is added manually for certain circumstances.
Reactions: krooney
I had the same issue after updating to 5.3. The issue appears to be related to the updated version of the intercept.lua script file dated when upgrade completed. I restored the intercept.lua file to the version of the previous version and call pickup with *8 works again.
The updated intercept.lua script causes an INVALID PROFILE error in the logs on call pickup.
