System Information Version4.2.4Git InformationBranch: 4.2
Commit: 347d3cbf77ffdc6b5cfd023e2e83c4050396eed0
Origin: https://github.com/fusionpbx/fusionpbx.git
Project Path/var/www/fusionpbxSwitch Version1.6.19 (64bit)
BACKGROUND
1) I have an extension with a DID attached to it.... x17
A) works perfectly, you call the DID # and the extension rings, answers and all is good
B) no answer, goes to voice mail
C) Can use the MENU: Extension->Choose the Extension(17)->Call Routing->Call Forward:ENABLE-> ANOTHER EXTENSION ==> WORKS PERFECTLY
2) I have an extension programmed to call out to a cell phone using a 11 digit, WORKS PERFECTLY
HERE IS THE PROBLEM:
If I MENU: Extension->Choose the Extension(17)->Call Routing->Call Forward:ENABLE-> 11-digit external # OR x250 ( already forwarding external )
A) If I call from an ext. to x17, forwards to external # no problem
B) If I call the DID that forwards to x17 ( and then on to external # ), I get no ring, no audio and a log full of errors ( see below ).
Any help will be appreciated.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [NOTICE] switch_channel.c:1104 New Channel sofia/external/559XXXXXXX@67.231.5.110 [c3c0751c-8f2f-4ff3-906d-c1ab545d98f1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_NEW (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:9873 sofia/external/559XXXXXXX@67.231.5.110 receiving invite from 63.247.69.226:5060 version: 1.6.19 -36-7a77e0b 64bit
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [received][100]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:7094 Remote SDP:
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 v=0
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 o=Sonus_UAC 617208 440933 IN IP4 67.231.5.110
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 s=SIP Media Capabilities
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 c=IN IP4 67.231.5.75
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 t=0 0
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 m=audio 28812 RTP/AVP 0 18 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=rtpmap:0 PCMU/8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=rtpmap:18 G729/8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=fmtp:18 annexb=no
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=rtpmap:101 telephone-event/8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=fmtp:101 0-15
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=ptime:20
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[GSM:3:8000:20:13200:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:3061 Set Codec sofia/external/559XXXXXXX@67.231.5.110 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_codec.c:111 sofia/external/559XXXXXXX@67.231.5.110 Original read codec set to PCMU:0
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4767 sofia/external/559XXXXXXX@67.231.5.110 Set 2833 dtmf send payload to 101 recv payload to 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:7507 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_NEW -> CS_INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:603 (sofia/external/559XXXXXXX@67.231.5.110) State NEW
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_INIT (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:627 (sofia/external/559XXXXXXX@67.231.5.110) State INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] mod_sofia.c:90 sofia/external/559XXXXXXX@67.231.5.110 SOFIA INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:40 sofia/external/559XXXXXXX@67.231.5.110 Standard INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:48 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_INIT -> CS_ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:627 (sofia/external/559XXXXXXX@67.231.5.110) State INIT going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_ROUTING (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_channel.c:2249 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change DOWN -> RINGING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] mod_sofia.c:143 sofia/external/559XXXXXXX@67.231.5.110 SOFIA ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:236 sofia/external/559XXXXXXX@67.231.5.110 Standard ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [INFO] mod_dialplan_xml.c:637 Processing ROBERT HALLETT <559XXXXXXX>->1559YYYYYYY in context public
2018-03-24 06:55:41.891885 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
2018-03-24 06:55:41.891885 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [public->1559YYYYYYY] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [1559YYYYYYY] destination_number(1559YYYYYYY) =~ /^(1559YYYYYYY)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_direction=inbound) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_direction=inbound)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_direction]=[inbound]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(domain_uuid=0db3211c-3475-46d1-8fd9-3a3a015fbaf3) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(domain_uuid=0db3211c-3475-46d1-8fd9-3a3a015fbaf3)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [domain_uuid]=[0db3211c-3475-46d1-8fd9-3a3a015fbaf3]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(domain_name=voip.cawia.com) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(domain_name=voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [domain_name]=[voip.cawia.com]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action transfer(17 XML voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:286 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_ROUTING -> CS_EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_EXECUTE (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_sofia.c:198 sofia/external/559XXXXXXX@67.231.5.110 SOFIA EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:328 sofia/external/559XXXXXXX@67.231.5.110 Standard EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 transfer(17 XML voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_ivr.c:2165 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_EXECUTE -> CS_ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [NOTICE] switch_ivr.c:2172 Transfer sofia/external/559XXXXXXX@67.231.5.110 to XML[17@voip.cawia.com]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_ROUTING (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_sofia.c:143 sofia/external/559XXXXXXX@67.231.5.110 SOFIA ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:236 sofia/external/559XXXXXXX@67.231.5.110 Standard ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [INFO] mod_dialplan_xml.c:637 Processing ROBERT HALLETT <559XXXXXXX>->17 in context voip.cawia.com
2018-03-24 06:55:41.911884 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
2018-03-24 06:55:41.931882 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->user_exists] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_exists] () =~ // break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2018-03-24 06:55:41.931882 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(user_exists=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.931882 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_exists]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_exists] ${user_exists}(true) =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(extension_uuid=${user_data ${destination_number}@${domain_name} var extension_uuid}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(extension_uuid=61d486bf-3bba-45ba-9286-a2672a0d0693)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.931882 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [extension_uuid]=[61d486bf-3bba-45ba-9286-a2672a0d0693]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(hold_music=${user_data ${destination_number}@${domain_name} var hold_music}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(hold_music=local_stream://default)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [hold_music]=[local_stream://default]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_all_enabled=${user_data ${destination_number}@${domain_name} var forward_all_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_all_enabled=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_all_enabled]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_all_destination=${user_data ${destination_number}@${domain_name} var forward_all_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_all_destination=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_all_destination]=[1559XXXXXXX]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_busy_enabled=${user_data ${destination_number}@${domain_name} var forward_busy_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_busy_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_busy_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_busy_destination=${user_data ${destination_number}@${domain_name} var forward_busy_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_busy_destination=*721559ZZZZZZZ)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_busy_destination]=[*721559ZZZZZZZ]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_no_answer_enabled=${user_data ${destination_number}@${domain_name} var forward_no_answer_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_no_answer_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_no_answer_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_no_answer_destination=${user_data ${destination_number}@${domain_name} var forward_no_answer_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_no_answer_destination=559ZZZZZZZ)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_no_answer_destination]=[559ZZZZZZZ]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_user_not_registered_enabled=${user_data ${destination_number}@${domain_name} var forward_user_not_registered_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_user_not_registered_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_user_not_registered_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_user_not_registered_destination=${user_data ${destination_number}@${domain_name} var forward_user_not_registered_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_user_not_registered_destination=559ZZZZZZZ)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_user_not_registered_destination]=[559ZZZZZZZ]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(do_not_disturb=${user_data ${destination_number}@${domain_name} var do_not_disturb}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(do_not_disturb=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [do_not_disturb]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_timeout=${user_data ${destination_number}@${domain_name} var call_timeout}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_timeout=30)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_timeout]=[30]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(missed_call_app=${user_data ${destination_number}@${domain_name} var missed_call_app}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(missed_call_app=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [missed_call_app]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(missed_call_data=${user_data ${destination_number}@${domain_name} var missed_call_data}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(missed_call_data=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [missed_call_data]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(toll_allow=${user_data ${destination_number}@${domain_name} var toll_allow}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(toll_allow=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [toll_allow]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_screen_enabled=${user_data ${destination_number}@${domain_name} var call_screen_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_screen_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_screen_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call-direction] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [call-direction] ${call_direction}(inbound) =~ /^(inbound|outbound|local)$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->variables] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [variables] () =~ // break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action export(origination_callee_id_name=${destination_number})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->user_record] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_record] () =~ // break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(user_record=${user_data ${destination_number}@${domain_name} var user_record}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(user_record=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_record]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
2018-03-24 06:55:41.991894 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
2018-03-24 06:55:41.991894 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(from_user_exists=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [from_user_exists]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_record] ${user_exists}(true) =~ /^true$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_record] ${call_direction}(inbound) =~ /^inbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^outbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^local$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->redial] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [redial] destination_number(17) =~ /^(redial|\*870)$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [redial] () =~ // break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->speed_dial] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [speed_dial] destination_number(17) =~ /^\*0(.*)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->siptrunk-jan8.11d] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [siptrunk-jan8.11d] destination_number(17) =~ /^\+?(\d{11})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->siptrunk-jan8.7d] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [siptrunk-jan8.7d] destination_number(17) =~ /^(\d{7})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->siptrunk-jan8.10d] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [siptrunk-jan8.10d] destination_number(17) =~ /^(\d{10})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->agent_status] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [agent_status] destination_number(17) =~ /^\*22$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->agent_status_id] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [agent_status_id] destination_number(17) =~ /^\*23$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->group-intercept] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [group-intercept] destination_number(17) =~ /^\*8$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->page-extension] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [page-extension] destination_number(17) =~ /^\*8(\d{2,7})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->eavesdrop] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [eavesdrop] destination_number(17) =~ /^\*33(\d{2,7})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call_privacy] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call_privacy] destination_number(17) =~ /^\*67(\d+)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call_return] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call_return] destination_number(17) =~ /^\*69$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->extension_queue] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [extension_queue] destination_number(17) =~ /^\*800(.*)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->intercept-ext] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [intercept-ext] destination_number(17) =~ /^\*\*(\d+)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->intercept-ext-polycom] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [intercept-ext-polycom] destination_number(17) =~ /^\*97(\d+)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->dx] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [dx] destination_number(17) =~ /^dx$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->att_xfer] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [att_xfer] destination_number(17) =~ /^att_xfer$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->extension-to-voicemail] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [extension-to-voicemail] ${user_exists}(true) =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [extension-to-voicemail] username(559XXXXXXX) =~ /^559XXXXXXX$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [extension-to-voicemail] destination_number(17) =~ /^559XXXXXXX$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->send_to_voicemail] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [send_to_voicemail] destination_number(17) =~ /^\*99(\d{2,10})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->vmain] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [vmain] destination_number(17) =~ /^vmain$|^\*4000$|^\*98$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->xfer_vm] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [xfer_vm] destination_number(17) =~ /^xfer_vm$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->is_transfer] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [is_transfer] destination_number(17) =~ /^is_transfer$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->vmain_user] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [vmain_user] destination_number(17) =~ /^\*97$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->Main Menu] continue=
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [Main Menu] destination_number(17) =~ /^16$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->cf] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [cf] destination_number(17) =~ /^cf$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->delay_echo] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [delay_echo] destination_number(17) =~ /^\*9195$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->echo] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [echo] destination_number(17) =~ /^\*9196$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->is_zrtp_secure] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 ANTI-Action eval(not_secure)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->milliwatt] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [milliwatt] destination_number(17) =~ /^\*9197$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->is_secure] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->tone_stream] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [tone_stream] destination_number(17) =~ /^\*9198$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->hold_music] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [hold_music] destination_number(17) =~ /^\*9664$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->recordings] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [recordings] destination_number(17) =~ /^\*(732)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->directory] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [directory] destination_number(17) =~ /^\*411$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->wake-up] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [wake-up] destination_number(17) =~ /^\*(925)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->valet_park] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [valet_park] destination_number(17) =~ /^(park\+)?(\*59[0-9][0-9])$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip
.*)@.*/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [valet_park] destination_number(17) =~ /^(park\+)?(\*59[0-9][0-9])$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->operator] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [operator] destination_number(17) =~ /^0$|^operator$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->operator-forward] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [operator-forward] destination_number(17) =~ /^\*000$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->do-not-disturb] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [do-not-disturb] destination_number(17) =~ /^\*77$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [do-not-disturb] destination_number(17) =~ /^\*78$|\*363$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [do-not-disturb] destination_number(17) =~ /^\*79$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call-forward] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call-forward] destination_number(17) =~ /^\*72$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call-forward] destination_number(17) =~ /^\*73$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call-forward] destination_number(17) =~ /^\*74$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call forward all] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [call forward all] ${user_exists}(true) =~ /^true/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [call forward all] ${forward_all_enabled}(true) =~ /^true/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action transfer(${forward_all_destination} XML ${domain_name})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:286 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_ROUTING -> CS_EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_EXECUTE (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_sofia.c:198 sofia/external/559XXXXXXX@67.231.5.110 SOFIA EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:328 sofia/external/559XXXXXXX@67.231.5.110 Standard EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 export(origination_callee_id_name=17)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[17]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(RFC2822_DATE=Sat, 24 Mar 2018 06:55:41 -0700)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [RFC2822_DATE]=[Sat, 24 Mar 2018 06:55:41 -0700]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 hash(insert/voip.cawia.com-last_dial/559XXXXXXX/17)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 eval(not_secure)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 transfer(1559XXXXXXX XML voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_ivr.c:2165 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_EXECUTE -> CS_ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [NOTICE] switch_ivr.c:2172 Transfer sofia/external/559XXXXXXX@67.231.5.110 to XML[1559XXXXXXX@voip.cawia.com]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_ROUTING (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_sofia.c:143 sofia/external/559XXXXXXX@67.231.5.110 SOFIA ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:236 sofia/external/559XXXXXXX@67.231.5.110 Standard ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [INFO] mod_dialplan_xml.c:637 Processing ROBERT HALLETT <559XXXXXXX>->1559XXXXXXX in context voip.cawia.com
2018-03-24 06:55:42.011885 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(user_exists=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_exists]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
2018-03-24 06:55:42.011885 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_record]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [from_user_exists]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [redial] destination_number(1559XXXXXXX) =~ /^(redial|\*870)$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [speed_dial] destination_number(1559XXXXXXX) =~ /^\*0(.*)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [siptrunk-jan8.11d] destination_number(1559XXXXXXX) =~ /^\+?(\d{11})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(sip_h_X-accountcode=${accountcode})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_direction=outbound)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action unset(call_timeout)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(hangup_after_bridge=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(effective_caller_id_name=${outbound_caller_id_name})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(effective_caller_id_number=${outbound_caller_id_number})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(inherit_codec=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(ignore_display_updates=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(callee_id_number=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(continue_on_fail=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action bridge(sofia/gateway/1f99a13d-179e-4b53-94b3-8bac79fd53ba/1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:286 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_ROUTING -> CS_EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_EXECUTE (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:198 sofia/external/559XXXXXXX@67.231.5.110 SOFIA EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:328 sofia/external/559XXXXXXX@67.231.5.110 Standard EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 export(origination_callee_id_name=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[1559XXXXXXX]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(RFC2822_DATE=Sat, 24 Mar 2018 06:55:42 -0700)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [RFC2822_DATE]=[Sat, 24 Mar 2018 06:55:42 -0700]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 hash(insert/voip.cawia.com-last_dial/559XXXXXXX/1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(sip_h_X-accountcode=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [sip_h_X-accountcode]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_direction=outbound)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_direction]=[outbound]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 unset(call_timeout)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1693 UNSET [call_timeout]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(hangup_after_bridge=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [hangup_after_bridge]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(effective_caller_id_name=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [effective_caller_id_name]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(effective_caller_id_number=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [effective_caller_id_number]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(inherit_codec=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [inherit_codec]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(ignore_display_updates=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [ignore_display_updates]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(callee_id_number=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [callee_id_number]=[1559XXXXXXX]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(continue_on_fail=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [continue_on_fail]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 bridge(sofia/gateway/1f99a13d-179e-4b53-94b3-8bac79fd53ba/1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_channel.c:1250 sofia/external/559XXXXXXX@67.231.5.110 EXPORTING[export_vars] [origination_callee_id_name]=[1559XXXXXXX] to event
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_ivr_originate.c:2142 Parsing global variables
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [NOTICE] switch_channel.c:1104 New Channel sofia/external/1559XXXXXXX [b823a582-8ba1-41e1-b701-c0688a9ed188]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:4819 (sofia/external/1559XXXXXXX) State Change CS_NEW -> CS_INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_INIT (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:627 (sofia/external/1559XXXXXXX) State INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:90 sofia/external/1559XXXXXXX SOFIA INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] sofia_glue.c:1295 sofia/external/1559XXXXXXX sending invite version: 1.6.19 -36-7a77e0b 64bit
b823a582-8ba1-41e1-b701-c0688a9ed188 Local SDP:
b823a582-8ba1-41e1-b701-c0688a9ed188 v=0
b823a582-8ba1-41e1-b701-c0688a9ed188 o=FreeSWITCH 1521875486 1521875487 IN IP4 54.241.55.222
b823a582-8ba1-41e1-b701-c0688a9ed188 s=FreeSWITCH
b823a582-8ba1-41e1-b701-c0688a9ed188 c=IN IP4 54.241.55.222
b823a582-8ba1-41e1-b701-c0688a9ed188 t=0 0
b823a582-8ba1-41e1-b701-c0688a9ed188 m=audio 24256 RTP/AVP 0 8 3 101 13
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:0 PCMU/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:8 PCMA/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:3 GSM/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:101 telephone-event/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=fmtp:101 0-16
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:13 CN/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=ptime:20
b823a582-8ba1-41e1-b701-c0688a9ed188 a=sendrecv
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:40 sofia/external/1559XXXXXXX Standard INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:48 (sofia/external/1559XXXXXXX) State Change CS_INIT -> CS_ROUTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:627 (sofia/external/1559XXXXXXX) State INIT going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_ROUTING (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [calling][0]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/1559XXXXXXX) State ROUTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:143 sofia/external/1559XXXXXXX SOFIA ROUTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_ivr_originate.c:67 (sofia/external/1559XXXXXXX) State Change CS_ROUTING -> CS_CONSUME_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/1559XXXXXXX) State ROUTING going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:662 (sofia/external/1559XXXXXXX) State CONSUME_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:662 (sofia/external/1559XXXXXXX) State CONSUME_MEDIA going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.091880 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [calling][0]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [proceeding][180]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] sofia.c:7094 Remote SDP:
b823a582-8ba1-41e1-b701-c0688a9ed188 o=Sonus_UAC 2067 8892 IN IP4 168.215.247.222
b823a582-8ba1-41e1-b701-c0688a9ed188 s=SIP Media Capabilities
b823a582-8ba1-41e1-b701-c0688a9ed188 c=IN IP4 4.55.10.66
b823a582-8ba1-41e1-b701-c0688a9ed188 m=audio 15806 RTP/AVP 0 101
b823a582-8ba1-41e1-b701-c0688a9ed188 a=fmtp:101 0-15
b823a582-8ba1-41e1-b701-c0688a9ed188 a=maxptime:20
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:3061 Set Codec sofia/external/1559XXXXXXX PCMU/8000 20 ms 160 samples 64000 bits 1 channels
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_codec.c:111 sofia/external/1559XXXXXXX Original read codec set to PCMU:0
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4767 sofia/external/1559XXXXXXX Set 2833 dtmf send payload to 101 recv payload to 101
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:6878 AUDIO RTP [sofia/external/1559XXXXXXX] 172.31.3.87 port 24256 -> 4.55.10.66 port 15806 codec: 0 ms: 20
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_rtp.c:4111 Starting timer [soft] 160 bytes per 20ms
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:7179 sofia/external/1559XXXXXXX Set 2833 dtmf send payload to 101
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:7186 sofia/external/1559XXXXXXX Set 2833 dtmf receive payload to 101
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:7209 sofia/external/1559XXXXXXX Set rtp dtmf delay to 40
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [NOTICE] sofia_media.c:92 Pre-Answer sofia/external/1559XXXXXXX!
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_channel.c:3474 (sofia/external/1559XXXXXXX) Callstate Change DOWN -> EARLY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_ivr_originate.c:410 Setting codec string on sofia/external/559XXXXXXX@67.231.5.110 to PCMU@8000h@20i
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [INFO] switch_ivr_originate.c:3654 Sending early media
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:6878 AUDIO RTP [sofia/external/559XXXXXXX@67.231.5.110] 172.31.3.87 port 22318 -> 67.231.5.75 port 28812 codec: 0 ms: 20
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_rtp.c:4111 Starting timer [soft] 160 bytes per 20ms
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:7179 sofia/external/559XXXXXXX@67.231.5.110 Set 2833 dtmf send payload to 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:7186 sofia/external/559XXXXXXX@67.231.5.110 Set 2833 dtmf receive payload to 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:7209 sofia/external/559XXXXXXX@67.231.5.110 Set rtp dtmf delay to 40
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] mod_sofia.c:2364 Ring SDP:
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 o=FreeSWITCH 1521877425 1521877426 IN IP4 54.241.55.222
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 s=FreeSWITCH
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 c=IN IP4 54.241.55.222
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 m=audio 22318 RTP/AVP 0 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=fmtp:101 0-16
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=sendrecv
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [NOTICE] mod_sofia.c:2367 Pre-Answer sofia/external/559XXXXXXX@67.231.5.110!
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_channel.c:3474 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change RINGING -> EARLY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [early][183]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_ivr_originate.c:3705 Originate Resulted in Success: [sofia/external/1559XXXXXXX]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] switch_ivr_bridge.c:1614 (sofia/external/1559XXXXXXX) State Change CS_CONSUME_MEDIA -> CS_EXCHANGE_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_EXCHANGE_MEDIA (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] switch_core_state_machine.c:653 (sofia/external/1559XXXXXXX) State EXCHANGE_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] mod_sofia.c:631 SOFIA EXCHANGE_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [completing][200]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] sofia.c:7091 Duplicate SDP
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [ready][200]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [NOTICE] sofia.c:8159 Channel [sofia/external/1559XXXXXXX] has been answered
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] switch_channel.c:3773 (sofia/external/1559XXXXXXX) Callstate Change EARLY -> ACTIVE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] switch_core_media.c:6861 Audio params are unchanged for sofia/external/559XXXXXXX@67.231.5.110.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] mod_sofia.c:850 Local SDP sofia/external/559XXXXXXX@67.231.5.110:
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 o=FreeSWITCH 1521877425 1521877427 IN IP4 54.241.55.222
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [completed][200]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [NOTICE] switch_ivr_bridge.c:623 Channel [sofia/external/559XXXXXXX@67.231.5.110] has been answered
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] switch_channel.c:3773 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change EARLY -> ACTIVE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.651888 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [ready][200]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [NOTICE] sofia.c:1012 Hangup sofia/external/559XXXXXXX@67.231.5.110 [CS_EXECUTE] [NORMAL_CLEARING]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_ivr_bridge.c:787 BRIDGE THREAD DONE [sofia/external/559XXXXXXX@67.231.5.110]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_ivr_bridge.c:787 BRIDGE THREAD DONE [sofia/external/1559XXXXXXX]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [NOTICE] switch_ivr_bridge.c:904 Hangup sofia/external/1559XXXXXXX [CS_EXCHANGE_MEDIA] [NORMAL_CLEARING]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:653 (sofia/external/1559XXXXXXX) State EXCHANGE_MEDIA going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_HANGUP (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:850 (sofia/external/1559XXXXXXX) Callstate Change ACTIVE -> HANGUP
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/1559XXXXXXX) State HANGUP
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:432 sofia/external/1559XXXXXXX Overriding SIP cause 480 with 200 from the other leg
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:438 Channel sofia/external/1559XXXXXXX hanging up, cause: NORMAL_CLEARING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:491 Sending BYE to sofia/external/1559XXXXXXX
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:60 sofia/external/1559XXXXXXX Standard HANGUP, cause: NORMAL_CLEARING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/1559XXXXXXX) State HANGUP going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:619 (sofia/external/1559XXXXXXX) State Change CS_HANGUP -> CS_REPORTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_REPORTING (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:938 (sofia/external/1559XXXXXXX) State REPORTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:174 sofia/external/1559XXXXXXX Standard REPORTING, cause: NORMAL_CLEARING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:938 (sofia/external/1559XXXXXXX) State REPORTING going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:610 (sofia/external/1559XXXXXXX) State Change CS_REPORTING -> CS_DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_session.c:1665 Session 1213 (sofia/external/1559XXXXXXX) Locked, Waiting on external entities
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_ivr_bridge.c:1715 sofia/external/559XXXXXXX@67.231.5.110 skip receive message [UNBRIDGE] (channel is hungup already)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_session.c:2815 sofia/external/559XXXXXXX@67.231.5.110 skip receive message [APPLICATION_EXEC_COMPLETE] (channel is hungup already)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_HANGUP (Cur 2 Tot 1213)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:850 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change ACTIVE -> HANGUP
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/559XXXXXXX@67.231.5.110) State HANGUP
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:438 Channel sofia/external/559XXXXXXX@67.231.5.110 hanging up, cause: NORMAL_CLEARING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:60 sofia/external/559XXXXXXX@67.231.5.110 Standard HANGUP, cause: NORMAL_CLEARING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/559XXXXXXX@67.231.5.110) State HANGUP going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:619 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_HANGUP -> CS_REPORTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_REPORTING (Cur 2 Tot 1213)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:938 (sofia/external/559XXXXXXX@67.231.5.110) State REPORTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [NOTICE] switch_core_session.c:1683 Session 1213 (sofia/external/1559XXXXXXX) Ended
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [NOTICE] switch_core_session.c:1687 Close Channel sofia/external/1559XXXXXXX [CS_DESTROY]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:741 (sofia/external/1559XXXXXXX) Running State Change CS_DESTROY (Cur 1 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:751 (sofia/external/1559XXXXXXX) State DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:343 sofia/external/1559XXXXXXX SOFIA DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:181 sofia/external/1559XXXXXXX Standard DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:751 (sofia/external/1559XXXXXXX) State DESTROY going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:174 sofia/external/559XXXXXXX@67.231.5.110 Standard REPORTING, cause: NORMAL_CLEARING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:938 (sofia/external/559XXXXXXX@67.231.5.110) State REPORTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:610 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_REPORTING -> CS_DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_session.c:1665 Session 1212 (sofia/external/559XXXXXXX@67.231.5.110) Locked, Waiting on external entities
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [NOTICE] switch_core_session.c:1683 Session 1212 (sofia/external/559XXXXXXX@67.231.5.110) Ended
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [NOTICE] switch_core_session.c:1687 Close Channel sofia/external/559XXXXXXX@67.231.5.110 [CS_DESTROY]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:741 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_DESTROY (Cur 0 Tot 1213)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:751 (sofia/external/559XXXXXXX@67.231.5.110) State DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] mod_sofia.c:343 sofia/external/559XXXXXXX@67.231.5.110 SOFIA DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:181 sofia/external/559XXXXXXX@67.231.5.110 Standard DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:751 (sofia/external/559XXXXXXX@67.231.5.110) State DESTROY going to sleep
Commit: 347d3cbf77ffdc6b5cfd023e2e83c4050396eed0
Origin: https://github.com/fusionpbx/fusionpbx.git
Project Path/var/www/fusionpbxSwitch Version1.6.19 (64bit)
BACKGROUND
1) I have an extension with a DID attached to it.... x17
A) works perfectly, you call the DID # and the extension rings, answers and all is good
B) no answer, goes to voice mail
C) Can use the MENU: Extension->Choose the Extension(17)->Call Routing->Call Forward:ENABLE-> ANOTHER EXTENSION ==> WORKS PERFECTLY
2) I have an extension programmed to call out to a cell phone using a 11 digit, WORKS PERFECTLY
HERE IS THE PROBLEM:
If I MENU: Extension->Choose the Extension(17)->Call Routing->Call Forward:ENABLE-> 11-digit external # OR x250 ( already forwarding external )
A) If I call from an ext. to x17, forwards to external # no problem
B) If I call the DID that forwards to x17 ( and then on to external # ), I get no ring, no audio and a log full of errors ( see below ).
Any help will be appreciated.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [NOTICE] switch_channel.c:1104 New Channel sofia/external/559XXXXXXX@67.231.5.110 [c3c0751c-8f2f-4ff3-906d-c1ab545d98f1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_NEW (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:9873 sofia/external/559XXXXXXX@67.231.5.110 receiving invite from 63.247.69.226:5060 version: 1.6.19 -36-7a77e0b 64bit
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [received][100]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:7094 Remote SDP:
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 v=0
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 o=Sonus_UAC 617208 440933 IN IP4 67.231.5.110
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 s=SIP Media Capabilities
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 c=IN IP4 67.231.5.75
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 t=0 0
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 m=audio 28812 RTP/AVP 0 18 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=rtpmap:0 PCMU/8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=rtpmap:18 G729/8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=fmtp:18 annexb=no
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=rtpmap:101 telephone-event/8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=fmtp:101 0-15
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=ptime:20
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[GSM:3:8000:20:13200:1]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:3061 Set Codec sofia/external/559XXXXXXX@67.231.5.110 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_codec.c:111 sofia/external/559XXXXXXX@67.231.5.110 Original read codec set to PCMU:0
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_media.c:4767 sofia/external/559XXXXXXX@67.231.5.110 Set 2833 dtmf send payload to 101 recv payload to 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] sofia.c:7507 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_NEW -> CS_INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:603 (sofia/external/559XXXXXXX@67.231.5.110) State NEW
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_INIT (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:627 (sofia/external/559XXXXXXX@67.231.5.110) State INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] mod_sofia.c:90 sofia/external/559XXXXXXX@67.231.5.110 SOFIA INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:40 sofia/external/559XXXXXXX@67.231.5.110 Standard INIT
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:48 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_INIT -> CS_ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:627 (sofia/external/559XXXXXXX@67.231.5.110) State INIT going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_ROUTING (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_channel.c:2249 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change DOWN -> RINGING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] mod_sofia.c:143 sofia/external/559XXXXXXX@67.231.5.110 SOFIA ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [DEBUG] switch_core_state_machine.c:236 sofia/external/559XXXXXXX@67.231.5.110 Standard ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.871932 [INFO] mod_dialplan_xml.c:637 Processing ROBERT HALLETT <559XXXXXXX>->1559YYYYYYY in context public
2018-03-24 06:55:41.891885 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
2018-03-24 06:55:41.891885 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [public->1559YYYYYYY] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [1559YYYYYYY] destination_number(1559YYYYYYY) =~ /^(1559YYYYYYY)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_direction=inbound) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_direction=inbound)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_direction]=[inbound]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(domain_uuid=0db3211c-3475-46d1-8fd9-3a3a015fbaf3) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(domain_uuid=0db3211c-3475-46d1-8fd9-3a3a015fbaf3)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [domain_uuid]=[0db3211c-3475-46d1-8fd9-3a3a015fbaf3]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(domain_name=voip.cawia.com) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(domain_name=voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [domain_name]=[voip.cawia.com]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action transfer(17 XML voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:286 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_ROUTING -> CS_EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_EXECUTE (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_sofia.c:198 sofia/external/559XXXXXXX@67.231.5.110 SOFIA EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:328 sofia/external/559XXXXXXX@67.231.5.110 Standard EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 transfer(17 XML voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_ivr.c:2165 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_EXECUTE -> CS_ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [NOTICE] switch_ivr.c:2172 Transfer sofia/external/559XXXXXXX@67.231.5.110 to XML[17@voip.cawia.com]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_ROUTING (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] mod_sofia.c:143 sofia/external/559XXXXXXX@67.231.5.110 SOFIA ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [DEBUG] switch_core_state_machine.c:236 sofia/external/559XXXXXXX@67.231.5.110 Standard ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.891885 [INFO] mod_dialplan_xml.c:637 Processing ROBERT HALLETT <559XXXXXXX>->17 in context voip.cawia.com
2018-03-24 06:55:41.911884 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
2018-03-24 06:55:41.931882 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->user_exists] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_exists] () =~ // break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2018-03-24 06:55:41.931882 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(user_exists=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.931882 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_exists]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_exists] ${user_exists}(true) =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(extension_uuid=${user_data ${destination_number}@${domain_name} var extension_uuid}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(extension_uuid=61d486bf-3bba-45ba-9286-a2672a0d0693)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.931882 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [extension_uuid]=[61d486bf-3bba-45ba-9286-a2672a0d0693]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(hold_music=${user_data ${destination_number}@${domain_name} var hold_music}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(hold_music=local_stream://default)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [hold_music]=[local_stream://default]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_all_enabled=${user_data ${destination_number}@${domain_name} var forward_all_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_all_enabled=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_all_enabled]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_all_destination=${user_data ${destination_number}@${domain_name} var forward_all_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_all_destination=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_all_destination]=[1559XXXXXXX]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_busy_enabled=${user_data ${destination_number}@${domain_name} var forward_busy_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_busy_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_busy_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_busy_destination=${user_data ${destination_number}@${domain_name} var forward_busy_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_busy_destination=*721559ZZZZZZZ)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_busy_destination]=[*721559ZZZZZZZ]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_no_answer_enabled=${user_data ${destination_number}@${domain_name} var forward_no_answer_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_no_answer_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_no_answer_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_no_answer_destination=${user_data ${destination_number}@${domain_name} var forward_no_answer_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_no_answer_destination=559ZZZZZZZ)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_no_answer_destination]=[559ZZZZZZZ]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_user_not_registered_enabled=${user_data ${destination_number}@${domain_name} var forward_user_not_registered_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_user_not_registered_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.951855 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_user_not_registered_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(forward_user_not_registered_destination=${user_data ${destination_number}@${domain_name} var forward_user_not_registered_destination}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(forward_user_not_registered_destination=559ZZZZZZZ)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [forward_user_not_registered_destination]=[559ZZZZZZZ]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(do_not_disturb=${user_data ${destination_number}@${domain_name} var do_not_disturb}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(do_not_disturb=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [do_not_disturb]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_timeout=${user_data ${destination_number}@${domain_name} var call_timeout}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_timeout=30)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_timeout]=[30]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(missed_call_app=${user_data ${destination_number}@${domain_name} var missed_call_app}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(missed_call_app=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [missed_call_app]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(missed_call_data=${user_data ${destination_number}@${domain_name} var missed_call_data}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(missed_call_data=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [missed_call_data]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(toll_allow=${user_data ${destination_number}@${domain_name} var toll_allow}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(toll_allow=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [toll_allow]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_screen_enabled=${user_data ${destination_number}@${domain_name} var call_screen_enabled}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_screen_enabled=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_screen_enabled]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call-direction] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [call-direction] ${call_direction}(inbound) =~ /^(inbound|outbound|local)$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->variables] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [variables] () =~ // break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action export(origination_callee_id_name=${destination_number})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->user_record] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_record] () =~ // break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(user_record=${user_data ${destination_number}@${domain_name} var user_record}) INLINE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(user_record=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.971884 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_record]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
2018-03-24 06:55:41.991894 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
2018-03-24 06:55:41.991894 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(from_user_exists=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [from_user_exists]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_record] ${user_exists}(true) =~ /^true$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [user_record] ${call_direction}(inbound) =~ /^inbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^outbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^local$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->redial] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [redial] destination_number(17) =~ /^(redial|\*870)$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [redial] () =~ // break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->speed_dial] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [speed_dial] destination_number(17) =~ /^\*0(.*)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->siptrunk-jan8.11d] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [siptrunk-jan8.11d] destination_number(17) =~ /^\+?(\d{11})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->siptrunk-jan8.7d] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [siptrunk-jan8.7d] destination_number(17) =~ /^(\d{7})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->siptrunk-jan8.10d] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [siptrunk-jan8.10d] destination_number(17) =~ /^(\d{10})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->agent_status] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [agent_status] destination_number(17) =~ /^\*22$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->agent_status_id] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [agent_status_id] destination_number(17) =~ /^\*23$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->group-intercept] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [group-intercept] destination_number(17) =~ /^\*8$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->page-extension] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [page-extension] destination_number(17) =~ /^\*8(\d{2,7})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->eavesdrop] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [eavesdrop] destination_number(17) =~ /^\*33(\d{2,7})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call_privacy] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call_privacy] destination_number(17) =~ /^\*67(\d+)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call_return] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call_return] destination_number(17) =~ /^\*69$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->extension_queue] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [extension_queue] destination_number(17) =~ /^\*800(.*)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->intercept-ext] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [intercept-ext] destination_number(17) =~ /^\*\*(\d+)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->intercept-ext-polycom] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [intercept-ext-polycom] destination_number(17) =~ /^\*97(\d+)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->dx] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [dx] destination_number(17) =~ /^dx$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->att_xfer] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [att_xfer] destination_number(17) =~ /^att_xfer$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->extension-to-voicemail] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [extension-to-voicemail] ${user_exists}(true) =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [extension-to-voicemail] username(559XXXXXXX) =~ /^559XXXXXXX$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [extension-to-voicemail] destination_number(17) =~ /^559XXXXXXX$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->send_to_voicemail] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [send_to_voicemail] destination_number(17) =~ /^\*99(\d{2,10})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->vmain] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [vmain] destination_number(17) =~ /^vmain$|^\*4000$|^\*98$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->xfer_vm] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [xfer_vm] destination_number(17) =~ /^xfer_vm$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->is_transfer] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [is_transfer] destination_number(17) =~ /^is_transfer$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->vmain_user] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [vmain_user] destination_number(17) =~ /^\*97$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->Main Menu] continue=
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [Main Menu] destination_number(17) =~ /^16$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->cf] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [cf] destination_number(17) =~ /^cf$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->delay_echo] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [delay_echo] destination_number(17) =~ /^\*9195$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->echo] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [echo] destination_number(17) =~ /^\*9196$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->is_zrtp_secure] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 ANTI-Action eval(not_secure)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->milliwatt] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [milliwatt] destination_number(17) =~ /^\*9197$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->is_secure] continue=true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->tone_stream] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [tone_stream] destination_number(17) =~ /^\*9198$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->hold_music] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [hold_music] destination_number(17) =~ /^\*9664$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->recordings] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [recordings] destination_number(17) =~ /^\*(732)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->directory] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [directory] destination_number(17) =~ /^\*411$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->wake-up] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [wake-up] destination_number(17) =~ /^\*(925)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->valet_park] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [valet_park] destination_number(17) =~ /^(park\+)?(\*59[0-9][0-9])$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [valet_park] destination_number(17) =~ /^(park\+)?(\*59[0-9][0-9])$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->operator] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [operator] destination_number(17) =~ /^0$|^operator$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->operator-forward] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [operator-forward] destination_number(17) =~ /^\*000$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->do-not-disturb] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [do-not-disturb] destination_number(17) =~ /^\*77$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [do-not-disturb] destination_number(17) =~ /^\*78$|\*363$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [do-not-disturb] destination_number(17) =~ /^\*79$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call-forward] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call-forward] destination_number(17) =~ /^\*72$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call-forward] destination_number(17) =~ /^\*73$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [call-forward] destination_number(17) =~ /^\*74$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 parsing [voip.cawia.com->call forward all] continue=false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [call forward all] ${user_exists}(true) =~ /^true/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [call forward all] ${forward_all_enabled}(true) =~ /^true/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action transfer(${forward_all_destination} XML ${domain_name})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:286 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_ROUTING -> CS_EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_EXECUTE (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_sofia.c:198 sofia/external/559XXXXXXX@67.231.5.110 SOFIA EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:328 sofia/external/559XXXXXXX@67.231.5.110 Standard EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 export(origination_callee_id_name=17)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[17]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(RFC2822_DATE=Sat, 24 Mar 2018 06:55:41 -0700)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [RFC2822_DATE]=[Sat, 24 Mar 2018 06:55:41 -0700]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 hash(insert/voip.cawia.com-last_dial/559XXXXXXX/17)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 eval(not_secure)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 transfer(1559XXXXXXX XML voip.cawia.com)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_ivr.c:2165 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_EXECUTE -> CS_ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [NOTICE] switch_ivr.c:2172 Transfer sofia/external/559XXXXXXX@67.231.5.110 to XML[1559XXXXXXX@voip.cawia.com]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_ROUTING (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] mod_sofia.c:143 sofia/external/559XXXXXXX@67.231.5.110 SOFIA ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [DEBUG] switch_core_state_machine.c:236 sofia/external/559XXXXXXX@67.231.5.110 Standard ROUTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:41.991894 [INFO] mod_dialplan_xml.c:637 Processing ROBERT HALLETT <559XXXXXXX>->1559XXXXXXX in context voip.cawia.com
2018-03-24 06:55:42.011885 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fd70c090be0 released.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(user_exists=false)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_exists]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
2018-03-24 06:55:42.011885 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fd70c090be0 Connected.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [user_record]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [from_user_exists]=[false]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [redial] destination_number(1559XXXXXXX) =~ /^(redial|\*870)$/ break=on-true
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (FAIL) [speed_dial] destination_number(1559XXXXXXX) =~ /^\*0(.*)$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Regex (PASS) [siptrunk-jan8.11d] destination_number(1559XXXXXXX) =~ /^\+?(\d{11})$/ break=on-false
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(sip_h_X-accountcode=${accountcode})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(call_direction=outbound)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action unset(call_timeout)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(hangup_after_bridge=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(effective_caller_id_name=${outbound_caller_id_name})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(effective_caller_id_number=${outbound_caller_id_number})
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(inherit_codec=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(ignore_display_updates=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(callee_id_number=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action set(continue_on_fail=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 Dialplan: sofia/external/559XXXXXXX@67.231.5.110 Action bridge(sofia/gateway/1f99a13d-179e-4b53-94b3-8bac79fd53ba/1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:286 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_ROUTING -> CS_EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/559XXXXXXX@67.231.5.110) State ROUTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_EXECUTE (Cur 1 Tot 1212)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:198 sofia/external/559XXXXXXX@67.231.5.110 SOFIA EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:328 sofia/external/559XXXXXXX@67.231.5.110 Standard EXECUTE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 export(origination_callee_id_name=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[1559XXXXXXX]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(RFC2822_DATE=Sat, 24 Mar 2018 06:55:42 -0700)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [RFC2822_DATE]=[Sat, 24 Mar 2018 06:55:42 -0700]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 hash(insert/voip.cawia.com-last_dial/559XXXXXXX/1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(sip_h_X-accountcode=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [sip_h_X-accountcode]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(call_direction=outbound)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [call_direction]=[outbound]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 unset(call_timeout)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1693 UNSET [call_timeout]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(hangup_after_bridge=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [hangup_after_bridge]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(effective_caller_id_name=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [effective_caller_id_name]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(effective_caller_id_number=)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [effective_caller_id_number]=[UNDEF]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(inherit_codec=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [inherit_codec]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(ignore_display_updates=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [ignore_display_updates]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(callee_id_number=1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [callee_id_number]=[1559XXXXXXX]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 set(continue_on_fail=true)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] mod_dptools.c:1548 SET sofia/external/559XXXXXXX@67.231.5.110 [continue_on_fail]=[true]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 EXECUTE sofia/external/559XXXXXXX@67.231.5.110 bridge(sofia/gateway/1f99a13d-179e-4b53-94b3-8bac79fd53ba/1559XXXXXXX)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_channel.c:1250 sofia/external/559XXXXXXX@67.231.5.110 EXPORTING[export_vars] [origination_callee_id_name]=[1559XXXXXXX] to event
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:42.011885 [DEBUG] switch_ivr_originate.c:2142 Parsing global variables
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [NOTICE] switch_channel.c:1104 New Channel sofia/external/1559XXXXXXX [b823a582-8ba1-41e1-b701-c0688a9ed188]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:4819 (sofia/external/1559XXXXXXX) State Change CS_NEW -> CS_INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_INIT (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:627 (sofia/external/1559XXXXXXX) State INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:90 sofia/external/1559XXXXXXX SOFIA INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] sofia_glue.c:1295 sofia/external/1559XXXXXXX sending invite version: 1.6.19 -36-7a77e0b 64bit
b823a582-8ba1-41e1-b701-c0688a9ed188 Local SDP:
b823a582-8ba1-41e1-b701-c0688a9ed188 v=0
b823a582-8ba1-41e1-b701-c0688a9ed188 o=FreeSWITCH 1521875486 1521875487 IN IP4 54.241.55.222
b823a582-8ba1-41e1-b701-c0688a9ed188 s=FreeSWITCH
b823a582-8ba1-41e1-b701-c0688a9ed188 c=IN IP4 54.241.55.222
b823a582-8ba1-41e1-b701-c0688a9ed188 t=0 0
b823a582-8ba1-41e1-b701-c0688a9ed188 m=audio 24256 RTP/AVP 0 8 3 101 13
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:0 PCMU/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:8 PCMA/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:3 GSM/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:101 telephone-event/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=fmtp:101 0-16
b823a582-8ba1-41e1-b701-c0688a9ed188 a=rtpmap:13 CN/8000
b823a582-8ba1-41e1-b701-c0688a9ed188 a=ptime:20
b823a582-8ba1-41e1-b701-c0688a9ed188 a=sendrecv
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:40 sofia/external/1559XXXXXXX Standard INIT
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:48 (sofia/external/1559XXXXXXX) State Change CS_INIT -> CS_ROUTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:627 (sofia/external/1559XXXXXXX) State INIT going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_ROUTING (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [calling][0]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/1559XXXXXXX) State ROUTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] mod_sofia.c:143 sofia/external/1559XXXXXXX SOFIA ROUTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_ivr_originate.c:67 (sofia/external/1559XXXXXXX) State Change CS_ROUTING -> CS_CONSUME_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:643 (sofia/external/1559XXXXXXX) State ROUTING going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:662 (sofia/external/1559XXXXXXX) State CONSUME_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.011885 [DEBUG] switch_core_state_machine.c:662 (sofia/external/1559XXXXXXX) State CONSUME_MEDIA going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:42.091880 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [calling][0]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [proceeding][180]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] sofia.c:7094 Remote SDP:
b823a582-8ba1-41e1-b701-c0688a9ed188 o=Sonus_UAC 2067 8892 IN IP4 168.215.247.222
b823a582-8ba1-41e1-b701-c0688a9ed188 s=SIP Media Capabilities
b823a582-8ba1-41e1-b701-c0688a9ed188 c=IN IP4 4.55.10.66
b823a582-8ba1-41e1-b701-c0688a9ed188 m=audio 15806 RTP/AVP 0 101
b823a582-8ba1-41e1-b701-c0688a9ed188 a=fmtp:101 0-15
b823a582-8ba1-41e1-b701-c0688a9ed188 a=maxptime:20
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:3061 Set Codec sofia/external/1559XXXXXXX PCMU/8000 20 ms 160 samples 64000 bits 1 channels
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_codec.c:111 sofia/external/1559XXXXXXX Original read codec set to PCMU:0
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:4767 sofia/external/1559XXXXXXX Set 2833 dtmf send payload to 101 recv payload to 101
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:6878 AUDIO RTP [sofia/external/1559XXXXXXX] 172.31.3.87 port 24256 -> 4.55.10.66 port 15806 codec: 0 ms: 20
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_rtp.c:4111 Starting timer [soft] 160 bytes per 20ms
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:7179 sofia/external/1559XXXXXXX Set 2833 dtmf send payload to 101
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:7186 sofia/external/1559XXXXXXX Set 2833 dtmf receive payload to 101
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_core_media.c:7209 sofia/external/1559XXXXXXX Set rtp dtmf delay to 40
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [NOTICE] sofia_media.c:92 Pre-Answer sofia/external/1559XXXXXXX!
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.271911 [DEBUG] switch_channel.c:3474 (sofia/external/1559XXXXXXX) Callstate Change DOWN -> EARLY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_ivr_originate.c:410 Setting codec string on sofia/external/559XXXXXXX@67.231.5.110 to PCMU@8000h@20i
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [INFO] switch_ivr_originate.c:3654 Sending early media
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:6878 AUDIO RTP [sofia/external/559XXXXXXX@67.231.5.110] 172.31.3.87 port 22318 -> 67.231.5.75 port 28812 codec: 0 ms: 20
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_rtp.c:4111 Starting timer [soft] 160 bytes per 20ms
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:7179 sofia/external/559XXXXXXX@67.231.5.110 Set 2833 dtmf send payload to 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:7186 sofia/external/559XXXXXXX@67.231.5.110 Set 2833 dtmf receive payload to 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_core_media.c:7209 sofia/external/559XXXXXXX@67.231.5.110 Set rtp dtmf delay to 40
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] mod_sofia.c:2364 Ring SDP:
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 o=FreeSWITCH 1521877425 1521877426 IN IP4 54.241.55.222
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 s=FreeSWITCH
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 c=IN IP4 54.241.55.222
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 m=audio 22318 RTP/AVP 0 101
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=fmtp:101 0-16
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 a=sendrecv
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [NOTICE] mod_sofia.c:2367 Pre-Answer sofia/external/559XXXXXXX@67.231.5.110!
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_channel.c:3474 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change RINGING -> EARLY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [early][183]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:43.291882 [DEBUG] switch_ivr_originate.c:3705 Originate Resulted in Success: [sofia/external/1559XXXXXXX]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] switch_ivr_bridge.c:1614 (sofia/external/1559XXXXXXX) State Change CS_CONSUME_MEDIA -> CS_EXCHANGE_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_EXCHANGE_MEDIA (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] switch_core_state_machine.c:653 (sofia/external/1559XXXXXXX) State EXCHANGE_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:43.291882 [DEBUG] mod_sofia.c:631 SOFIA EXCHANGE_MEDIA
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [completing][200]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] sofia.c:7091 Duplicate SDP
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] sofia.c:7084 Channel sofia/external/1559XXXXXXX entering state [ready][200]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [NOTICE] sofia.c:8159 Channel [sofia/external/1559XXXXXXX] has been answered
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:44.492002 [DEBUG] switch_channel.c:3773 (sofia/external/1559XXXXXXX) Callstate Change EARLY -> ACTIVE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] switch_core_media.c:6861 Audio params are unchanged for sofia/external/559XXXXXXX@67.231.5.110.
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] mod_sofia.c:850 Local SDP sofia/external/559XXXXXXX@67.231.5.110:
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 o=FreeSWITCH 1521877425 1521877427 IN IP4 54.241.55.222
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [completed][200]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [NOTICE] switch_ivr_bridge.c:623 Channel [sofia/external/559XXXXXXX@67.231.5.110] has been answered
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.511886 [DEBUG] switch_channel.c:3773 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change EARLY -> ACTIVE
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:44.651888 [DEBUG] sofia.c:7084 Channel sofia/external/559XXXXXXX@67.231.5.110 entering state [ready][200]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [NOTICE] sofia.c:1012 Hangup sofia/external/559XXXXXXX@67.231.5.110 [CS_EXECUTE] [NORMAL_CLEARING]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_ivr_bridge.c:787 BRIDGE THREAD DONE [sofia/external/559XXXXXXX@67.231.5.110]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_ivr_bridge.c:787 BRIDGE THREAD DONE [sofia/external/1559XXXXXXX]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [NOTICE] switch_ivr_bridge.c:904 Hangup sofia/external/1559XXXXXXX [CS_EXCHANGE_MEDIA] [NORMAL_CLEARING]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:653 (sofia/external/1559XXXXXXX) State EXCHANGE_MEDIA going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_HANGUP (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:850 (sofia/external/1559XXXXXXX) Callstate Change ACTIVE -> HANGUP
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/1559XXXXXXX) State HANGUP
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:432 sofia/external/1559XXXXXXX Overriding SIP cause 480 with 200 from the other leg
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:438 Channel sofia/external/1559XXXXXXX hanging up, cause: NORMAL_CLEARING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:491 Sending BYE to sofia/external/1559XXXXXXX
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:60 sofia/external/1559XXXXXXX Standard HANGUP, cause: NORMAL_CLEARING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/1559XXXXXXX) State HANGUP going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:619 (sofia/external/1559XXXXXXX) State Change CS_HANGUP -> CS_REPORTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/1559XXXXXXX) Running State Change CS_REPORTING (Cur 2 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:938 (sofia/external/1559XXXXXXX) State REPORTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:174 sofia/external/1559XXXXXXX Standard REPORTING, cause: NORMAL_CLEARING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:938 (sofia/external/1559XXXXXXX) State REPORTING going to sleep
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:610 (sofia/external/1559XXXXXXX) State Change CS_REPORTING -> CS_DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_session.c:1665 Session 1213 (sofia/external/1559XXXXXXX) Locked, Waiting on external entities
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_ivr_bridge.c:1715 sofia/external/559XXXXXXX@67.231.5.110 skip receive message [UNBRIDGE] (channel is hungup already)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_session.c:2815 sofia/external/559XXXXXXX@67.231.5.110 skip receive message [APPLICATION_EXEC_COMPLETE] (channel is hungup already)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:650 (sofia/external/559XXXXXXX@67.231.5.110) State EXECUTE going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_HANGUP (Cur 2 Tot 1213)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:850 (sofia/external/559XXXXXXX@67.231.5.110) Callstate Change ACTIVE -> HANGUP
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/559XXXXXXX@67.231.5.110) State HANGUP
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:438 Channel sofia/external/559XXXXXXX@67.231.5.110 hanging up, cause: NORMAL_CLEARING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:60 sofia/external/559XXXXXXX@67.231.5.110 Standard HANGUP, cause: NORMAL_CLEARING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:852 (sofia/external/559XXXXXXX@67.231.5.110) State HANGUP going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:619 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_HANGUP -> CS_REPORTING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:584 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_REPORTING (Cur 2 Tot 1213)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:938 (sofia/external/559XXXXXXX@67.231.5.110) State REPORTING
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [NOTICE] switch_core_session.c:1683 Session 1213 (sofia/external/1559XXXXXXX) Ended
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [NOTICE] switch_core_session.c:1687 Close Channel sofia/external/1559XXXXXXX [CS_DESTROY]
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:741 (sofia/external/1559XXXXXXX) Running State Change CS_DESTROY (Cur 1 Tot 1213)
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:751 (sofia/external/1559XXXXXXX) State DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] mod_sofia.c:343 sofia/external/1559XXXXXXX SOFIA DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:181 sofia/external/1559XXXXXXX Standard DESTROY
b823a582-8ba1-41e1-b701-c0688a9ed188 2018-03-24 06:55:51.271910 [DEBUG] switch_core_state_machine.c:751 (sofia/external/1559XXXXXXX) State DESTROY going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:174 sofia/external/559XXXXXXX@67.231.5.110 Standard REPORTING, cause: NORMAL_CLEARING
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:938 (sofia/external/559XXXXXXX@67.231.5.110) State REPORTING going to sleep
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:610 (sofia/external/559XXXXXXX@67.231.5.110) State Change CS_REPORTING -> CS_DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_session.c:1665 Session 1212 (sofia/external/559XXXXXXX@67.231.5.110) Locked, Waiting on external entities
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [NOTICE] switch_core_session.c:1683 Session 1212 (sofia/external/559XXXXXXX@67.231.5.110) Ended
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [NOTICE] switch_core_session.c:1687 Close Channel sofia/external/559XXXXXXX@67.231.5.110 [CS_DESTROY]
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:741 (sofia/external/559XXXXXXX@67.231.5.110) Running State Change CS_DESTROY (Cur 0 Tot 1213)
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:751 (sofia/external/559XXXXXXX@67.231.5.110) State DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] mod_sofia.c:343 sofia/external/559XXXXXXX@67.231.5.110 SOFIA DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:181 sofia/external/559XXXXXXX@67.231.5.110 Standard DESTROY
c3c0751c-8f2f-4ff3-906d-c1ab545d98f1 2018-03-24 06:55:51.311886 [DEBUG] switch_core_state_machine.c:751 (sofia/external/559XXXXXXX@67.231.5.110) State DESTROY going to sleep
