Cannot get incoming call to route through incoming [SOLVED]
question
All incoming calls are getting routed directly to the first extension. Incoming routes are bypassed. In Destinations -> Destination I have tried the Callcentric trunk number, the DID number (11 digits). Incoming route is bypassed. Even if I put a nonsense number in Destinations -> Destination the call will go through to the first extension. But if I disable the Destination the incoming call does not go through.
Is there a default rule somewhere that passes everything once it gets to Destination? I am working with a fresh AWS EC2 installation of FusionPBX, I am doing 'systemctl restart freeswitch' before each test just to make sure the current changes are in effect.
I used ChatGPT to install FusionPBX configured with a secure public IP address. At one point it told me to edit the postgres database to update the domain name. This made the FusionPBX GUI and the database out of sync, and is the source of the original problem. ChatGPT then tried to solve it by having me change other configurations which complicated everything. I switched to Google Gemini and told it the problem and the history of installation. It recognized the cause of the problem immediately. Gemini then directed me through a successful install. My notes are as follows.
Also for Callcentric specifically. The Dialplan > Inbound Rules must be changed
from: condition destination_number ^(TRUNK_NUMBER)$
to: condition ${sip_to_user} ^(DID_NUMBER)$
My installation procedure to install FusionPBX on a fresh AWS EC2 instance (minimum t3.micro) with Debian 12.
Prerequisite: HTTPS certificate configured in AWS Route53. This install uses CERTBOT with Letsencrypt.
On the local machine (if using Linux)
ssh-keygen -f "/home/YOUR_HOME/.ssh/known_hosts" -R "IP_address"
ssh -i YOUR_KEY.pem admin@IP_address
On the remote machine (I was root)
ADD SWAP
fallocate -l 1G /swapfile
chmod 600 /swapfile
mkswap /swapfile
swapon /swapfile
edit /etc/fstab and add at end of file:
/swapfile none swap defaults 0 0
timedatectl set-timezone YOUR_TIME_ZONE
apt install zip
INSTALL SYSTEM
sudo apt update
sudo apt full-upgrade -y
sudo apt install zip
sudo apt install -y git
cd /usr/src
sudo git clone https://github.com/fusionpbx/fusionpbx-install.sh.git
cd fusionpbx-install.sh/debian
sudo ./install.sh
At the end it will print something like this. Save it.
Username: admin@IP_address
Password: xxxxxxxxxx
Before touching Certbot or NGINX, change the domain inside FusionPBX.
Log into the FusionPBX web interface using the server's raw IP address.
In Advanced > Domains, edit IP address to domain name. Save. Logout.
INSTALL CERTBOT
apt install dnsutils
apt install certbot python3-certbot-nginx
certbot certonly --nginx -d YOUR_DOMAIN_NAME -d www.YOUR_DOMAIN_NAME
Certificate is saved at: /etc/letsencrypt/live/YOUR_DOMAIN_NAME/fullchain.pem
Key is saved at: /etc/letsencrypt/live/YOUR_DOMAIN_NAME/privkey.pem
edit /etc/nginx/sites-available/fusionpbx
Find and change these lines in section 443 ssl server:
ssl_certificate /etc/letsencrypt/live/YOUR_DOMAIN_NAME/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/YOUR_DOMAIN_NAME/privkey.pem;
Check the installation:
nginx -t (Checks the syntax)
systemctl reload nginx
certbot renew --dry-run
This confirms which certificate is actually being served:
openssl s_client -connect YOUR_DOMAIN_NAME:443 -servername YOUR_DOMAIN_NAME | openssl x509 -noout -dates -issuer
sftp -i YOUR_KEY.pem admin@IP_address
sudo su
cd /etc/freeswitch/tls
Build agent.pem file (full chain + private key):
cat /etc/letsencrypt/live/fullchain.pem /etc/letsencrypt/live/privkey.pem > /etc/freeswitch/tls/agent.pem
chmod 644 agent.pem
chgrp www-data:www-data *
mv wss.pem wss.pem.old
ln -sf /etc/letsencrypt/live/YOUR_DOMAIN_NAME/privkey.pem /etc/freeswitch/tls/key.pem
ln -sf /etc/letsencrypt/live/YOUR_DOMAIN_NAME/fullchain.pem /etc/freeswitch/tls/wss.pem
ln -sf /etc/freeswitch/tls/agent.pem /etc/freeswitch/tls/tls.pem
Directory /etc/freeswitch/tls should now look like this:
ls -l
-rw-r--r-- 1 www-data www-data 3084 Apr 26 02:22 agent.pem
-rw-rw---- 1 www-data www-data 4980 Apr 26 02:07 dtls-srtp.pem
lrwxrwxrwx 1 www-data www-data 42 Apr 26 02:44 key.pem -> /etc/letsencrypt/live/YOUR_DOMAIN_NAME/privkey.pem
lrwxrwxrwx 1 www-data www-data 29 Apr 26 02:46 tls.pem -> /etc/freeswitch/tls/agent.pem
lrwxrwxrwx 1 www-data www-data 44 Apr 26 02:44 wss.pem -> /etc/letsencrypt/live/YOUR_DOMAIN_NAME/fullchain.pem
-rw-rw---- 1 www-data www-data 4976 Apr 26 02:07 wss.pem.old
Logout, clear the browser certificate for that site. Login using the domain name the first time: admin@YOUR_DOMAIN_NAME.
You should see the connection is secure symbol in the browser.
I've never done it this way.
Follow the proper installation.
Get it from git
wget -O - https://raw.githubusercontent.com/fusionpbx/fusionpbx-install.sh/master/debian/pre-install.sh | sh;
Then I edit the config for install
nano /usr/src/fusionpbx-install.sh/debian/resources/config.sh
In the first line,
domain_name=
I edit and add the domain name for which I already created the DNS A record.
I use a custom one that will serve for access to the PBX, not for customers.
Then I run the install script
cd /usr/src/fusionpbx-install.sh/debian && ./install.sh
This installs FusionPBX with a domain and not a public IP, and there is no editing of anything after installation.
In that file you can choose your FusionPBX branch, PHP version, Postgres version, and some other things that you should just leave as default.
Debian 13 is recommended.
I also use the FusionPBX Let's Encrypt script located in same folder as config.sh.
Just run the letsencrypt.sh, and add domains and email, then run systemctl restart nginx.
Use dehydrated either manually or via cron job to renew.
Reactions: question
ChatGPT is the absolute WORST AI to use for programming and troubleshooting. Grok or Gemini are much more reliable. Better yet, follow the instructions at the product's web site.
