SOLVED Can't Dial 911, 411, 311, or 933 (Telnyx issue)
mfelli
16
Hello all!
I have dialplans setup to catch 933 specifically and [2-9]11 to route to an outbound gateway that currently works for regular phone numbers. But I have an issue where it's treating 911,411,311 as local extensions and not hitting the SIP gateway at all. 933 on the other hand is treated as an outbound call however a channel is never created so it doesn't actually reach the SIP gateway either (double checked on their logs).
I have no idea what I'm missing here, something is intercepting this dialplan ahead of the dialplans in FusionPBX and I can't find it anywhere. The only FreeSwitch dialplan xml that's not noload is the empty one. Or if it's the default 2-7 extension length that's the problem, I can't find a way to change that either. All my extensions are 4 digits, so it would be ok to change that.
Any help would be great, thank you.
We also have no idea what you are missing and nor will we until you post a log!
mfelli
16
D'oh I should know better!
Extension 6866 dialing 411
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.486272 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/6866@server.com:5060 [d177ae30-29d3-4935-a7c9-81183753638e]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.486272 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/6866@server.com:5060) Running State Change CS_NEW (Cur 1 Tot 22628)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.486272 [DEBUG] sofia.c:9873 sofia/internal/6866@server.com:5060 receiving invite from 172.117.224.220:5060 version: 1.6.19 -36-7a77e0b 64bit
2018-01-01 17:20:35.486272 [DEBUG] sofia.c:10044 IP 172.117.224.220 Rejected by acl "domains". Falling back to Digest auth.
2018-01-01 17:20:35.486272 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [411@server.com] from ip 172.117.224.220
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.486272 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/6866@server.com:5060) State NEW
2018-01-01 17:20:35.486272 [DEBUG] sofia.c:2334 detaching session d177ae30-29d3-4935-a7c9-81183753638e
2018-01-01 17:20:35.506232 [DEBUG] sofia.c:2442 Re-attaching to session d177ae30-29d3-4935-a7c9-81183753638e
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.506232 [DEBUG] sofia.c:9873 sofia/internal/6866@server.com:5060 receiving invite from 172.117.224.220:5060 version: 1.6.19 -36-7a77e0b 64bit
2018-01-01 17:20:35.506232 [DEBUG] sofia.c:10044 IP 172.117.224.220 Rejected by acl "domains". Falling back to Digest auth.
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] sofia.c:7084 Channel sofia/internal/6866@server.com:5060 entering state [received][100]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] sofia.c:7094 Remote SDP:
d177ae30-29d3-4935-a7c9-81183753638e v=0
d177ae30-29d3-4935-a7c9-81183753638e o=- 20006 20006 IN IP4 172.117.224.220
d177ae30-29d3-4935-a7c9-81183753638e s=SDP data
d177ae30-29d3-4935-a7c9-81183753638e c=IN IP4 172.117.224.220
d177ae30-29d3-4935-a7c9-81183753638e t=0 0
d177ae30-29d3-4935-a7c9-81183753638e m=audio 12418 RTP/AVP 9 0 8 18 101
d177ae30-29d3-4935-a7c9-81183753638e a=rtpmap:9 G722/8000
d177ae30-29d3-4935-a7c9-81183753638e a=rtpmap:0 PCMU/8000
d177ae30-29d3-4935-a7c9-81183753638e a=rtpmap:8 PCMA/8000
d177ae30-29d3-4935-a7c9-81183753638e a=rtpmap:18 G729/8000
d177ae30-29d3-4935-a7c9-81183753638e a=fmtp:18 annexb=no
d177ae30-29d3-4935-a7c9-81183753638e a=rtpmap:101 telephone-event/8000
d177ae30-29d3-4935-a7c9-81183753638e a=fmtp:101 0-15
d177ae30-29d3-4935-a7c9-81183753638e a=ptime:20
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G722:9:8000:20:64000:1]/[G722:9:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [G722:9:8000:20:64000:1] ++++ is saved as a match
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G722:9:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[GSM:3:8000:20:13200:1]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:3061 Set Codec sofia/internal/6866@server.com:5060 G722/8000 20 ms 160 samples 64000 bits 1 channels
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_codec.c:111 sofia/internal/6866@server.com:5060 Original read codec set to G722:9
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_media.c:4767 sofia/internal/6866@server.com:5060 Set 2833 dtmf send payload to 101 recv payload to 101
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] sofia.c:7507 (sofia/internal/6866@server.com:5060) State Change CS_NEW -> CS_INIT
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/6866@server.com:5060) Running State Change CS_INIT (Cur 1 Tot 22628)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/6866@server.com:5060) State INIT
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] mod_sofia.c:90 sofia/internal/6866@server.com:5060 SOFIA INIT
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:40 sofia/internal/6866@server.com:5060 Standard INIT
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/6866@server.com:5060) State Change CS_INIT -> CS_ROUTING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/6866@server.com:5060) State INIT going to sleep
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/6866@server.com:5060) Running State Change CS_ROUTING (Cur 1 Tot 22628)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_channel.c:2249 (sofia/internal/6866@server.com:5060) Callstate Change DOWN -> RINGING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/6866@server.com:5060) State ROUTING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] mod_sofia.c:143 sofia/internal/6866@server.com:5060 SOFIA ROUTING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [DEBUG] switch_core_state_machine.c:236 sofia/internal/6866@server.com:5060 Standard ROUTING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.546195 [INFO] mod_dialplan_xml.c:637 Processing 6866 <6866>->411 in context server.com
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Telnyx_Outbound.bx11] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Telnyx_Outbound.bx11] ${user_exists}() =~ /false/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Telnyx_Outbound.x11] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Telnyx_Outbound.x11] ${user_exists}() =~ /false/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->user_exists] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [user_exists] () =~ // break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2018-01-01 17:20:35.566188 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7ff88c0d8d90 Connected.
2018-01-01 17:20:35.566188 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7ff88c0d8d90 released.
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(user_exists=false)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.566188 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [user_exists]=[false]
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->caller-details] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(caller_destination=${destination_number}) INLINE
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(caller_destination=411)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.566188 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [caller_destination]=[411]
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(caller_id_name=${caller_id_name}) INLINE
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(caller_id_name=6866)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.566188 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [caller_id_name]=[6866]
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(caller_id_number=${caller_id_number}) INLINE
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(caller_id_number=6866)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.566188 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [caller_id_number]=[6866]
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->call-direction] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 ANTI-Action set(call_direction=local)
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->variables] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [variables] () =~ // break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action export(origination_callee_id_name=${destination_number})
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->user_record] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [user_record] () =~ // break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(user_record=${user_data ${destination_number}@${domain_name} var user_record}) INLINE
2018-01-01 17:20:35.586189 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7ff88c0d8d90 Connected.
2018-01-01 17:20:35.586189 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7ff88c0d8d90 released.
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(user_record=)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.586189 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [user_record]=[UNDEF]
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(from_user_exists=true)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.586189 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [from_user_exists]=[true]
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${call_direction}() =~ /^inbound$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${call_direction}() =~ /^outbound$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${call_direction}() =~ /^local$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(from_user_record=)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [from_user_record]=[UNDEF]
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->redial] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [redial] destination_number(411) =~ /^(redial|\*870)$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [redial] () =~ // break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->default_caller_id] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [default_caller_id] ${emergency_caller_id_number}(18056444074) =~ /^$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [default_caller_id] ${outbound_caller_id_number}(18056444074) =~ /^$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Telnyx_Outbound.10d] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [Telnyx_Outbound.10d] ${user_exists}(false) =~ /false/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Telnyx_Outbound.10d] destination_number(411) =~ /^(\d{10})$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Telnyx_Outbound.d11] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [Telnyx_Outbound.d11] ${user_exists}(false) =~ /false/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Telnyx_Outbound.d11] destination_number(411) =~ /^(\d{11})$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Telnyx_Outbound.inum] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [Telnyx_Outbound.inum] ${user_exists}(false) =~ /false/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Telnyx_Outbound.inum] destination_number(411) =~ /^0118835100\d{8}$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->ring group] continue=
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1100$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1099$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->West Night IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [West Night IVR] destination_number(411) =~ /^6961$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->West Night MA IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [West Night MA IVR] destination_number(411) =~ /^6963$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1149$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Johnson Night MA IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Johnson Night MA IVR] destination_number(411) =~ /^6968$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->East Night MA IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [East Night MA IVR] destination_number(411) =~ /^6958$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->East Day MA IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [East Day MA IVR] destination_number(411) =~ /^6957$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->West Day MA IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [West Day MA IVR] destination_number(411) =~ /^6962$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->East Day IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [East Day IVR] destination_number(411) =~ /^6955$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Johnson Day IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Johnson Day IVR] destination_number(411) =~ /^6965$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->East Night IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [East Night IVR] destination_number(411) =~ /^6956$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Johnson Night IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Johnson Night IVR] destination_number(411) =~ /^6966$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1199$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1050$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1097$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Johnson Day MA IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Johnson Day MA IVR] destination_number(411) =~ /^6967$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1198$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^1098$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [ring group] destination_number(411) =~ /^6899$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->West Day IVR] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [West Day IVR] destination_number(411) =~ /^6960$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Telnyx_Outbound.933] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (PASS) [Telnyx_Outbound.933] ${user_exists}(false) =~ /false/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Telnyx_Outbound.933] destination_number(411) =~ /^\d{1}33$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->agent_status] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [agent_status] destination_number(411) =~ /^\*22$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->agent_status_id] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [agent_status_id] destination_number(411) =~ /^\*23$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->page-extension] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [page-extension] destination_number(411) =~ /^\*0(\d{2,7})$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->call_privacy] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call_privacy] destination_number(411) =~ /^\*67(\d+)$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->call_return] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call_return] destination_number(411) =~ /^\*69$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->intercept-ext] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [intercept-ext] destination_number(411) =~ /^\*\*(\d+)$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->intercept-ext-polycom] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [intercept-ext-polycom] destination_number(411) =~ /^\*97(\d+)$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->extension_queue] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [extension_queue] destination_number(411) =~ /^\*800(.*)$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Johnson_Medical_Records] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Johnson_Medical_Records] destination_number(411) =~ /^7101$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->dx] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [dx] destination_number(411) =~ /^dx$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->extension-to-voicemail] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->Johnson-Main-Fax] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [Johnson-Main-Fax] destination_number(411) =~ /^6907$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->send_to_voicemail] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [send_to_voicemail] destination_number(411) =~ /^\*99(\d{2,10})$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->att_xfer] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [att_xfer] destination_number(411) =~ /^att_xfer$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->East-Main-Fax] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [East-Main-Fax] destination_number(411) =~ /^6902$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->vmain] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [vmain] destination_number(411) =~ /^vmain$|^\*4000$|^\*98$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->xfer_vm] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [xfer_vm] destination_number(411) =~ /^xfer_vm$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->vmain_user] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [vmain_user] destination_number(411) =~ /^\*97$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->is_transfer] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [is_transfer] destination_number(411) =~ /^is_transfer$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->] continue=
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [] destination_number(411) =~ /^(?:flow\+)?\*7004$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [] destination_number(411) =~ /^7004$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [] destination_number(411) =~ /^(?:flow\+)?\*7003$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [] destination_number(411) =~ /^7003$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [] destination_number(411) =~ /^(?:flow\+)?\*7002$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [] destination_number(411) =~ /^7002$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->cf] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [cf] destination_number(411) =~ /^cf$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->delay_echo] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [delay_echo] destination_number(411) =~ /^\*9195$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->echo] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [echo] destination_number(411) =~ /^\*9196$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->milliwatt] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [milliwatt] destination_number(411) =~ /^\*9197$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->is_zrtp_secure] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 ANTI-Action eval(not_secure)
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->tone_stream] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [tone_stream] destination_number(411) =~ /^\*9198$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->is_secure] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->hold_music] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [hold_music] destination_number(411) =~ /^\*9664$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->recordings] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [recordings] destination_number(411) =~ /^\*(732)$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->directory] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [directory] destination_number(411) =~ /^\*411$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->wake-up] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [wake-up] destination_number(411) =~ /^\*(925)$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->valet_park_johnson] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_johnson] destination_number(411) =~ /^(park\+)?(\*51[6-7][0-9])$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_johnson] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_johnson] destination_number(411) =~ /^(park\+)?(\*51[6-7][0-9])$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->valet_park_east] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_east] destination_number(411) =~ /^(park\+)?(\*51[2-3][0-9])$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_east] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_east] destination_number(411) =~ /^(park\+)?(\*51[2-3][0-9])$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->valet_park_hq] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_hq] destination_number(411) =~ /^(park\+)?(\*59[8-9][0-9])$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_hq] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_hq] destination_number(411) =~ /^(park\+)?(\*59[8-9][0-9])$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->valet_park_west] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_west] destination_number(411) =~ /^(park\+)?(\*51[4-5][0-9])$/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_west] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [valet_park_west] destination_number(411) =~ /^(park\+)?(\*51[4-5][0-9])$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->operator] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [operator] destination_number(411) =~ /^0$|^operator$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->operator-forward] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [operator-forward] destination_number(411) =~ /^\*000$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->do-not-disturb] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [do-not-disturb] destination_number(411) =~ /^\*77$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [do-not-disturb] destination_number(411) =~ /^\*78$|\*363$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [do-not-disturb] destination_number(411) =~ /^\*79$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->call-forward] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call-forward] destination_number(411) =~ /^\*72$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call-forward] destination_number(411) =~ /^\*73$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call-forward] destination_number(411) =~ /^\*74$/ break=on-true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->call forward all] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call forward all] ${user_exists}(false) =~ /^true/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->follow-me] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [follow-me] destination_number(411) =~ /^\*21$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->clear_sip_auto_answer] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [clear_sip_auto_answer] ${click_to_call}() =~ /true/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->talking clock date and time] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [talking clock date and time] destination_number(411) =~ /^\*9172$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->talking clock time] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [talking clock time] destination_number(411) =~ /^\*9170$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->talking clock date] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [talking clock date] destination_number(411) =~ /^\*9171$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->call_screen] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [call_screen] ${call_screen_enabled}(false) =~ /^true$/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->local_extension] continue=true
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [local_extension] ${user_exists}(false) =~ /true/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 parsing [server.com->voicemail] continue=false
d177ae30-29d3-4935-a7c9-81183753638e Dialplan: sofia/internal/6866@server.com:5060 Regex (FAIL) [voicemail] ${user_exists}(false) =~ /true/ break=on-false
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/6866@server.com:5060) State Change CS_ROUTING -> CS_EXECUTE
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/6866@server.com:5060) State ROUTING going to sleep
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/6866@server.com:5060) Running State Change CS_EXECUTE (Cur 1 Tot 22628)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/6866@server.com:5060) State EXECUTE
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] mod_sofia.c:198 sofia/internal/6866@server.com:5060 SOFIA EXECUTE
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:328 sofia/internal/6866@server.com:5060 Standard EXECUTE
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(call_direction=local)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [call_direction]=[local]
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 export(origination_callee_id_name=411)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[411]
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 set(RFC2822_DATE=Mon, 01 Jan 2018 17:20:35 -0800)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] mod_dptools.c:1548 SET sofia/internal/6866@server.com:5060 [RFC2822_DATE]=[Mon, 01 Jan 2018 17:20:35 -0800]
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 hash(insert/server.com-last_dial/6866/411)
d177ae30-29d3-4935-a7c9-81183753638e EXECUTE sofia/internal/6866@server.com:5060 eval(not_secure)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [NOTICE] switch_core_state_machine.c:385 sofia/internal/6866@server.com:5060 has executed the last dialplan instruction, hanging up.
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/6866@server.com:5060 [CS_EXECUTE] [NORMAL_CLEARING]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/6866@server.com:5060) State EXECUTE going to sleep
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/6866@server.com:5060) Running State Change CS_HANGUP (Cur 1 Tot 22628)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/6866@server.com:5060) Callstate Change RINGING -> HANGUP
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/6866@server.com:5060) State HANGUP
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] mod_sofia.c:438 Channel sofia/internal/6866@server.com:5060 hanging up, cause: NORMAL_CLEARING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] mod_sofia.c:577 Responding to INVITE with: 480
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:60 sofia/internal/6866@server.com:5060 Standard HANGUP, cause: NORMAL_CLEARING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/6866@server.com:5060) State HANGUP going to sleep
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/6866@server.com:5060) State Change CS_HANGUP -> CS_REPORTING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/6866@server.com:5060) Running State Change CS_REPORTING (Cur 1 Tot 22628)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.606188 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/6866@server.com:5060) State REPORTING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_state_machine.c:174 sofia/internal/6866@server.com:5060 Standard REPORTING, cause: NORMAL_CLEARING
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/6866@server.com:5060) State REPORTING going to sleep
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/6866@server.com:5060) State Change CS_REPORTING -> CS_DESTROY
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_session.c:1665 Session 22628 (sofia/internal/6866@server.com:5060) Locked, Waiting on external entities
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [NOTICE] switch_core_session.c:1683 Session 22628 (sofia/internal/6866@server.com:5060) Ended
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [NOTICE] switch_core_session.c:1687 Close Channel sofia/internal/6866@server.com:5060 [CS_DESTROY]
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_state_machine.c:741 (sofia/internal/6866@server.com:5060) Running State Change CS_DESTROY (Cur 0 Tot 22628)
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/6866@server.com:5060) State DESTROY
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] mod_sofia.c:343 sofia/internal/6866@server.com:5060 SOFIA DESTROY
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_state_machine.c:181 sofia/internal/6866@server.com:5060 Standard DESTROY
d177ae30-29d3-4935-a7c9-81183753638e 2018-01-01 17:20:35.626188 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/6866@server.com:5060) State DESTROY going to sleep
mfelli
16
I was testing it in different spots. Last on my list, first on my list etc. And I apologize because I just found out Telnyx doesn't provide these services other than 911.
I really appreciate you jumping in to help.
