Click-To-Call Issue
Robert Birch
123
I am using Click-To-Call for a client and it is working well. Came across a small issue, where I don't see the Destination Caller ID Name and Number being passed to the actual API call.
If I do it from the webpage, fill in all the options, click Call, it works but the API code put at the top of the page only shows origination_caller_id_name and origination_caller_id_number. Nothing for destination.
Because they are not set, it uses the caller_id information for the extension I send the call to. I need that to be different.
Is it possible to get this fixed? I'm not much of a programmer (know enough to follow the code). Would it just be adding destination_caller_id_name and number to the string that gets generated by the php file?
Thanks.
