Hello!
I would like to configure a DDI which would be a numbering range.
A single trunk gateway account is provided by the provider which I have configured on fusion, but which accepts in / out calls from 10 different numbers.
Example
Principal:
01000000
Secondary:
01000001
01000002
01000003
01000004
and so on ..
Then the gateway is configured on 01000000.
The problem is that if I configure the number 01000001 in the inbound routes and call it, the call does not work.
If, on the other hand, I configure the main 01000000 as input, they all work but I have no way to differentiate them.
I would like to configure inbound for example
01000001 -> internal 101
01000002 -> internal 102
It appears that fusion does not accept anything other than the main gateway number as an entry rule.
Do you have any advice?
Example
Principal:
01000000
Secondary:
01000001
01000002
01000003
01000004
and so on ..
