Connect fusionpbx with obihai
wimy
13
Can you connect fusionpbx with obihai 200. I think obihai 200 is a sip trunk for fusionpbx and I try but not success. Could you help me, please? Thanks you very much
I was able to have obihai 100 connected to fusionpbx through the use of VoIP gateway. Neogate/Yeastar TA410. I used the FXO port of TA410 to connect to the phone line of obihai and configured the TA410 as gateway in the fusionpbx.
If I didnt answer to your situation, I hope I helped you to look at other solution.
Thanks.
Thanks.
could you review online my problem? I can't connect obihai to fusionPbx. Thank you very much
Within obihai, do you have an option to setup an extension? If not - you will need a analog line (pots to your provider, I assume google voice because, I use that setup) to sip (voip) gateway. This gateway is TA410.
My apologies if I have mixed the terminology. From general question you asked without much detail, I made an assumption that you were trying to send call outbound through obihai.
Yes, I use google voice. But I don't know setup gateway in fusionpbx.
can you provide the screenshot of obihai configuration to do with extensions.
I haven't configed. Because I don't know value in it.
You will need a gateway, because obihai acts as a sip phone with google voice as service provider. Obihai in return converts digital signal (voip) to analog. Basically it is an ata device with google voice as a service provider
so I need to buy gateways Ta410
Sorry for the delay, Not necessarily TA410. you just have to search for a gateway that supports FXO (connection from POTS, i.e dialtone from provider, in your case it is obihai). I was able to get TA410 for around $50 on ebay and use it. There is also FXS, you do not want that for dialing out. it is for allowing the non-voip devices to connect to the voip based system, i.e pbx
I had equipment for gateway but I still call out net work. Recived packet still 0%.
