DigitalDaz Administrator Staff member Sep 29, 2016 3,089 588 113 Mar 9, 2022 #2 Yes, though its not a very nice thing to do if you are not a member. Is open source though so nothing stopping you.
D dbz195 Member Feb 3, 2021 43 1 8 37 Mar 9, 2022 #3 Yes true, that being said do you know where to modify it, cant seem to find it.
A ad5ou Active Member Jun 12, 2018 893 205 43 Mar 9, 2022 #4 The easy way is documented in the paid member section of fusionpbx.com. The undocumented route is to inspect the php files to sort out the easy way or brute force way of modifying the text shown in the actual php file.
