Create Superadmin for all domains
moe
Dear all,
While trying to delete certain domains from the FusionPBX portal, by mistake we deleted all superadmins and now unable to log as superadmin although admin is still available.
I tried following this article https://docs.fusionpbx.com/en/latest/additional_information/password_reset.html but it didn't do anything. When I try to login with admin user after the recovery process it brings a blank dashboard.
I would appreciate your help in knowing how to recover the superadmin again.
Thank you
Personally, I would restore the database backup which you do hopefully have, though this can be tricky if time has passed and vital data is in the database now. Otherwise, I'd say edit the database and insert the relevant user back into v_users and v_group_users just like the installer would. Note you'll have to figure out the domain UUID from the database too. And definitely take a backup before you even touch the database, and know how to restore it if needed.
Line 71 of the finish.sh from the installer.
Don't run the installer again though. You will probably wipe your install.
