SOLVED Dial out on an alternate port not working
magic.coast.user
I need to dynamically dial end points that may be on random SIP ports ( not 5060 ).
I have tried adding the port to the dial string like this: user@<ip address>:5070 but it connects and hangs up. The server log says:
BYE due to: Reason: SIP;cause=500;text="Internal Error"
Anyone have any ideas about how I can specify an alternate port in the dial plan?
That's what I did, but I can see in the logs that it mangles the address like this:
${caller_destination}(xx.xxx.xxx.1515070) -- see how it removes the colon? this is supposed to be ....151:5070
[SOLVED] strange thing.
Had to read the incoming destination number in a lua script, parse it into IP:port and then transfer it back into internal.
Once it comes back into internal, the destination_number is correct, so I can then bridge it out to the correct user@${destination_number} which contains the :port.
