Diversion Header
ridvan
12
I am trying to set diversion header for a forwarded call in my outbound route. The problem is even though I set sip_h_Diversion as a random string for test, or a valid Diversion header in that manner, it does not show up in the sip package. Can anybody look if I'm doing something wrong?
I am triyng like this:
I don't know where you are putting it but have you tried export instead of set.
Also, make sure to flush cache.
Added the diversion header to the call-forward-all dialplan in FusionPBX 4.5 a couple months ago. If you have upgraded then delete the dialplan and run App Defaults.
Hi @markjcrane
I also add diversion header to call_forward_all like that:
sip_h_Diversion=somecallerid@somedomain
This didn't work.
1. Is this format is valid?
When i add like that:
sip_h_Diversion=Test
It works.
Between those changes, i restart freeswitch and flush the cache, but the changes take effect delay.
2. Could you explain how you did it?
Freeswitch will allow you to set a diversion header with an invalid URI prior to the bridge statement. A valid format would look something like this:
sip_h_Diversion=<sip:somecallerid@somedomain>;reason=unavailable
It doesn't work, when a call to an extension, part of a ring group or ivr, have set the call forward to external number, it do the forward, but doesn't set the diversion header.
Only on direct calls to the extension, the diversion header is set.
Diversion header is needed for some people and for others it creates problems with their VoIP providers. So anywhere that we add it will have to be a way to make it optional rather than hard coded into the code.
Off course, I'm not talking about making them hard-coded, but optional.
We all know that there is providers out there, that do not honour the SIP standar and did "their things". but the Diversion Headers on FusionPBX should be simple to let them work as optional from the gateway menu, for example.
