SOLVED Domain specific provisioning settings
Conker
12
Hi All,
I have a domain that needs Attended Transfer while the rest of the Domains stay on the default Blind Transfer. Though, I can't get it to work. I copied the setting I needed from the Default Settings page into the Domain, made sure it was set to enable, made sure that the Provisioning Config was calling the correct variable, and had the phone pull down a new config. But it is still not changing the transfer mode. Do custom settings in the Domain page work?
I even tried factory defaulting the phone to see if it was having issues re-writing the config, but even on a fresh phone it doesn't make the change. Any ideas?
195
Domain specific settings work.
Be sure to click “reload” on default settings page after making changes
Conker
12
Tried that. Factory reset the phone and tested. Still pulling down the default "Blind Transfer"
paradym
11
Download the provision file (meaning the one on the device page) and check it over to ensure that configuration is being set.
Conker
12
I figured it out. I had to copy over the yealink_provision_url and set it to the domain because it kept applying the generic URL.
