Duplicate cdrs and recordings
Neyamt
56
I am facing duplicate cdrs and recordings while using ring group with enterprise option. any idea how to resolve this ?
Problem is it's not really a fault with the CDRs, it does create those legs on enterprise. The only way I can think of would be to heavily modify /var/www/fusionpbx/app/xml_cdr/resources/classes/xml_cdr.php.
I do agree, it's annoying having to explain it to users, being able to filter out any calls that are a 'clone-of' might be useful.
@hfoster thank you for replying. if it was only duplicate cdrs and recording with same extension, it was fine somehow. but its showing same cdrs, same timedate, same call duration and same record with two to three other extension which are under same ring group. it confuse while checking the records and cdrs.
