SOLVED Emergency numbers
wouam31
115
Hi all,
I'm looking for where to put emergency numbers in fusionpbx in order to present a different number than the normal one.
I saw that in extension you could configure the number presented during the emergency call.
But I can't find where to put the emergency numbers!
If I understood correctly, the one taken into account is 911 except that in my country it is not 911...
I don't know if I was clear
Thanks in advance!
If you are wanting to know how to create a dial plan for emergencies services, create the 911 outbound route, then edit the two dial plans created and change the 911/933 numbers to your country emergency service number(s) and emergency service test number(s).
Set the correct DIDs in the extensions emergency CID name and number locations.
Fulfill your providers requirements for the DIDs physical locations.
I am assuming your question is not about emergency dialing list on a phone.
Reactions: wouam31
