EXT BLF with Call retrieve
bdmonsey
158
I followed instructions on the following page to do a DSS Key as BLF to be able to monitor the other extension and at the same time be able to clicking on that BLF key to retrieve that incoming call and displays on my screen that the other extension has an incoming call.
I was able to do it manually when I logged in directly to phone, for some reason there's one line missing in fusionpbx that doesnt make this feature possible with auto provision, Can you guide me how I would do this with auto provision?
This is a snapshot of my config.
It should work automatically. On my setup nothing was changed to get this functionality to work.
What is the firmware on the T29?
I'm using Yealinks as well, different model though.
This is a model I have not used before; however as per Yealink's site the newest firmware is 46.83.0.120. Try installing that one. I'm thinking the firmware might be beta or corrupt.
The DSS Keys on my T54W does not have the ** in the extension field and works as expected.
