K krooney Member Jun 18, 2018 181 16 18 Sep 2, 2019 #1 Hey guys i would need tips on where to look for faxing issues it was working great until recently dont know what happened may e after update it broke but just realized it now. Any tips on where to look would help thanks! FYI Remote inbox works
K krooney Member Jun 18, 2018 181 16 18 Sep 8, 2019 #4 @markjcrane Could you point me where to look for troubleshooting on this Thanks
M markjcrane Well-Known Member Staff member Jul 22, 2018 803 327 63 51 Sep 8, 2019 #5 Go to default settings and search for smtp settings under fax category disable the smtp settings that are empty. Then try again. Last edited: Oct 2, 2019
K krooney Member Jun 18, 2018 181 16 18 Sep 8, 2019 #6 @markjcrane Thank you for the quick reply but still no luck anywhere i can look to see if there is some kind of error log or something. When i try to run curl for testing it just hangs and nothing happens. When i send with the GUI it works, receiving works fax to email, remote inbox also works Just email to fax stopped working, Weird
M mattswainston Member Sep 27, 2018 48 1 8 54 Oct 1, 2019 #7 I also have this issue - could do with some docs on how to troubleshoot this - did you ever get it working?
