Fax issue using Fax Server in Fusion
kwangmien
59
I am using Fusion version 4.5.10. The fax that i sent using the Applications=>Fax Server in Fusion will not go through.
The scenario is :
a. I upload the PDF to be faxed in Fax Server
b. When the fax is sent, base on the wireshark capture, the fax call is established. The rtp stream is using g711 ulaw.
But after 3 secs, there is a Re-Invite. In the re-invite SDP , there are T.38 settings.
Can anyone advise how i can disable the Re-INVITE with T.38 settings ? I have disabled the fax_enable_t38 in Advanced=> Default_Settings.
But still there is Re-INVITE sent during the Fax Call.
Thanks.
Regards,
Kwang Mien
