FreeSWITCH DB location
DownUnder
24
I have tried changing the location of the FreeSWITCH db under:
Advanced -> Default Setting -> switch -> db
However, FreeSWITCH is still using the default location. Any suggestions?
Changing the core-db-name in /etc/freeswitch/autoload_configs/switch.conf.xml does the trick, may the setting isn't implemented in fusionPBX?
Not in the gui but then why would you want to move the DB??
Many of us just load it into RAM.
Hi Daz,
The idea is to move it to a ramdrive, I just wonder why the option is in the GUI but it doesn't actually do anything.
Just add this to fstab, reboot and you are done:
tmpfs /var/lib/freeswitch/db tmpfs defaults 0 0
