Freeswitch High CPU Issue (Probably BLF related)
ntt
I don't know if this is the right section, so please admin move this thread if there is a better section.
I'm using freeswitch 1.6.20, fusionpbx 4.5.12, centos 7.7 with 32Gb of ram and a dual cpu Intel(R) Xeon(R) E5649. I have only 48 extension with 50 gateway and a lot of calls (about 1.500 per day). The problem is that I see high cpu consumption by freeswitch and I do not understand why. The only thing I noticed is that the problem could be related to BLF. I see in logs "bursts" of requests like this:
cat /var/log/freeswitch/freeswitch.log | grep "192\.168\.1\.208"
2020-04-06 09:49:49.136415 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6000@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.176428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6001@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.216429 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6002@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.256429 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6003@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.336430 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6005@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.396408 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6006@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.436429 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6007@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.476426 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6009@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.516428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6010@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.556425 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6011@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.596426 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6012@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.716439 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6014@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.756441 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6015@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.796427 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6016@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.856429 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6018@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.916430 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6019@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.956423 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6020@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:49.996423 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6021@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.076430 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6023@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.116428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6024@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.156428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6025@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.196430 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6026@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.236428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6027@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.296436 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6028@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.316423 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6029@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.436435 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6031@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.476434 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6032@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.516425 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6033@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.556430 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6034@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.596428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6035@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.636428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6036@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.676428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6037@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.776407 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6039@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.816394 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6040@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.876437 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6041@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.916400 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6042@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.956428 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6043@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:50.996429 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6044@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.036424 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6045@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.116433 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6047@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.176422 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6048@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.216433 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6049@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.256433 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6098@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.296433 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6099@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.336403 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6100@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:49:51.396433 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [6409@xxx.yyy.mydomain.com] from ip 192.168.1.208
2020-04-06 09:55:02.996389 [WARNING] sofia_reg.c:1792 SIP auth challenge (REGISTER) on sofia profile 'internal' for [6008@xxx.yyy.mydomain.com] from ip 192.168.1.208
and this kind of message is repeated by all extension in the lan.
Please note that I have freeswitch with ip 192.168.1.5 and all extensions are in the same lan (except a couple). I'm using old linksys SPA962, Cisco Spa525g, YealinkT29 It seems that cpu consumption grows when there are these messages in log.
Please, I need some advise in order to identify and solve the issue.
Thank you,
Marco
That looks like some sort of potential hack and has nothing to do with blf.
Please, give me some advice in order to identify the problem. Actually port 5060/udp is open for all ips, but I have some doubts: requests come from phones in local lan and I'm sure that this is not an attack.
It seems to me as a blf problem because every time a call is received, all attendant console need to be updated. Anyway, the idea that cpu of freeswitch can reach 200% it's strange for me.
Thank you for you support
You need to post more logs the log you have posted indicates an extensions is calling many others. They are calls it is attempting to initiate.
Unfortunately I don't know which log should I share. I'm checking /var/log/freeswitch.log and it seems the problem is not related to a particular event (e.g.: receiving a call from a gateway). It seems some kind of "polling" made by extensions using an INVITE. Have you some idea on how I can debug this behavior? Can I use sngrep and filter only with INVITE requests? I need to understand why all extensions send INVITE to each other, or at least this seems to be the problem
You do not poll with an invite, just post a longer version of the freeswitch log rather than grepping it.
An INVITE is the initiation of a call or can be used during an ongoing call to refresh the session but it is certainly not used to poll anything.
ok. I can post a 10MB log but there are a lot of sensitive information. Is there a best practice or should I try to remove sensitive information by hand?
Thank you
DigitalDaz, I'm trying to debug in order to provide better logs. I've created a new profile named internal.lan on port 5061 and registered only one extension using this profile. Then I launched tcpdump with
tcpdump -i em1 -n port 5061
and attached log file here. Basically I see that after the "REGISTER" part, the extension (with ip 192.168.1.208) send a lot of SUBSCRIBE to freeswitch, one for each other extension. Is this a normal behavior? Furthermore I see a lot of NOTIFY from freeswitch to the extension.
As a side note, extension registers to "xxx.yyy.mydomain.com" that is the domain I created in fusionpbx, using an outbound proxy 192.168.1.5 that is the local ip of freeswitch. I did this because xxx.yyy.mydomain.com has a public ip and I'd like to use local ip address for traffic in lan. Is this correct?
Thank you
Thank you
Hey @ntt , I have a similar issue, did you ever get this resolved? Was it really due to BLF?
