freeswitch lua scripts do not exist in default directory on container environment
Mojy2021
Hi Guys
I installed fusionPBX on Docker. I noticed that freeswitch scripts directory (/usr/share/freeswitch/scripts) is empty. freeswitch complains "cannot open /usr/share/freeswitch/scripts/app.lua: No such file or directory"! The required scripts reside in /var/www/fusionpbx/app/scripts/resources/scripts/ although. I copied the scripts from /var/www/fusionpbx/app/scripts/resources/scripts/ to /usr/share/freeswitch/scripts manually but no success!!!.
By the way, I run the fusionpbx Docker container using both --privileged and unprivileged method but no success yet.
How can I solve this problem? Please HELP me
Thanks in advance.
