Freeswitch Wireshark RTP Audio Decoding
jrosetto
71
I am attempting to get a wireshark capture from tcpdump and everything seems to be working as expected except wireshark doesn't seem to match the RTP streams with the VOIP Call for most calls. I am running about 40 extensions over TCP 5060 and TLS 5061 currently and I have loaded my private key and I am decrypting the SIP packets correctly.
Any suggestions to get the RTP to line up with all phone calls?
You may like to post the command you are doing to capture it.
Thanks for the response
I am currently using this command but am open to suggestions
/usr/sbin/tcpdump -ni eth0 -s 0 -w - portrange 5060-5061 or portrange 16384-32768
From the lack of responses does this mean that it should be working with the command I am using?
