fs_path not being used for INVITE issue
Mikey
15
I have a two FS node setup. Both sharing the same DB. fs_path is set to true. I see fs_path set correct when running the command "show registrations" on each node.
My issue is when I have extension 100 registered on node1 and extension 200 registered on node2. Extension 100 and 200 can not call each other. Looking at the INVITE I dont see fs_path being passed/used.
How do I get FS to realize extension 200 is on a different server and use the fs_path? I have not modified any dialplans and everything else so far are default settings.
Update with more info;
In the FS logs I see the correct fs_path where it says "Parsing global variables"
However immediately after it says
"Setting proxy route to sofia/internal/100@mainsipdomain.com"
Then the INVITE is sent to the sip domain not the domain of the node from fs_path
Solved this! For anyone else that has this issue here is the solution;
Modify dialplan local_extension.
Change the bridge line to "sofia_contact ${destination_number}@${domain_name}"
This seems get the users registration info with the correct fs_path
