Fusion 4.4 Debain 9 Incoming Call Issue
Robert Birch
117
I built a new Fusion 4.4 machine on Debian 9. Built everything up like I nomally did on 4.2 on Debain 8. Phones provision correctly. Can call extension to extension, outgoing works. Incoming does not.
I receive this in the logs:
2019-02-27 15:45:36.957677 [WARNING] sofia_reg.c:2935 Can't find user [gw+5a0de595-2cd7-42fe-8c1f-94d50570a648@<External IP>] from <IP of Proxy>
You must define a domain called '<External IP>' in your directory and add a user with the id="gw+5a0de595-2cd7-42fe-8c1f-94d50570a648" attribute
The server is on AWS. I have set external_sip_ip and external_rtp_ip to the External IP Address.
Not sure what I am missing.
Thanks.
Success!!! That was the problem. Is there a list of these type of things that have changed?
Thanks for the help.
