A problem I just noticed.
For example, I goto Advanced > Default Settings. It doesn't render everything. It stops showing anything after "auto_login". I can hit refresh several times and it will eventually display or if I leave the page and come back, after several attempts, it will display more. Attached a screenshot.
Doing the same thing on call recordings. It shows 2 recordings but says there's 1722.... and under call detail records, same problem. It pulled the latest, upgraded schema, menu's, and permissions. Updated Centos 7 but it didn't change anything.
There is an error in the nginx logs about permission error on a .php file. the user freeswitch has rwx on all files under /var/www/fusionpbx, so I'm not sure where the problem is. I found mention of a nginx proxy folder but I don't see one listed under /var/cache for nginx.
Anyone have any ideas?
