Fusionpbx Auto dialer for Voice Broadcast
Maani
Hi
Do you know an open source voice broadcast solution with Fusionpbx ?
Existing call broadcast module with reattempt could be useful .
Regards.
Maani
@markjcrane
Is there any Feature List of Paid call broadcast module of Fusionpbx?
Is it support Fax broadcast ? Is there any demo site ?
What is maximum simultaneous call support?(or what is call attempts per second?)
thanks
Kenny Riley
243
I would be interested in this as well... some sort of a paid module that enabled the broadcast feature to be used as a full blown auto dialer.
Kenny Riley
243
Soft of -- the broadcast module is what I could consider a light dialer. It has the ability to upload CSV files and dial numbers automatically but it doesn't have the ability to output any reporting or automatically recycle leads/numbers in the list -- that I know of at least.
But as far as a full blown dialer that has the ability to create multiple campaigns, output reports and recycle leads, I would probably use Vicidial or Go Auto Dial.
