FusionPBX calls rejected due to missing Stir/Shaken attestation
dcitelecom
172
Does anyone have Stir/Shaken attestation working in FusionPBX?
All our gateways are configured with sip CID type = PID and caller ID in FROM, but recently many of our providers are rejecting Canada and USA calls with a "No Identity" error, which means the provider requires a verified identity header (such as STIR/SHAKEN) but none was provided. If this trend continues, FusionPBX won't be able to make calls anymore. I know that FS_PBX has a Stir/Shaken module but I don't want to switch unless I have no choice. Any ideas?
Who is your VoIP provider? You don't have to answer. BulkVS can do Stir/Shaken does this for free for their customers. Telonium is another company that will do this for a lower price than the other Stir/Shaken providers. FusionPBX, we will have Stir/Shaken is on our roadmap as a high priority.
If I remember right, someone on this forum got Stir/Shaken working, and then FS PBX asked about it, and then it was contributed to them. As far as I'm aware, this is an extra fee.
This means that at the very moment, BulkVS or Telonium may be the best options in the meantime.
https://www.bulkvs.com/
https://sti.telonium.com/
I sent them an email, asking how this would work, but I suspect I would have to switch my inbound DIDs and outbound termination to them, which is not really what I want.
@dcitelecom You're right; FS PBX has a dedicated STIR SHAKEN module. You can use any provider, and each call will carry Attestation A, which is the highest level of verification.
Unfortunately, the FS PBX module costs $100 per month, which is the same cost as using a third-party authentication service.
i use skyetel and they will assert all your outgoing calls as long as the number is with them in your account, seams simple and works perfect
The problem with this approach is that you are bound to a single provider and you are not getting the best rates. We use at least 10 outbound providers, and the DID is only registered with one of them.
Something else to consider. recent FCC mandate requires VoIP resellers to do their own stir shaken. You cant legally rely on your carrier to do it for you if the phone bill is coming from your own company.
Reactions: Architect
The key difference is that you handle everything locally on your server, which means you don't have to rely on any third-party services. Even a 302 redirect can introduce overhead and a slight delay to your requests. Additionally, I'm uncertain if anyone can still provide you with Attestation A if you're not managing it yourself. The industry is generally moving towards having all providers sign their own calls, as mentioned by @ja133.
Our module is included with certain support plans, so there's no additional charge.
