M Master Member Apr 23, 2023 36 1 8 22 May 2, 2023 #1 Hello I installed FusionPBX on Amazon Web Server and most IP’s are getting blocked and the IP’s that are open I can’t hear sound eg calls are on mute
datafanatics Member Dec 9, 2019 43 2 8 Brandon, MS www.datafanatics.com May 19, 2023 #2 You have to open up all of the ports in the firewall or you will get the mute issue you are having. Look specifically at the RTP UDP section. Firewall — FusionPBX Docs documentation docs.fusionpbx.com
hfoster Active Member Jan 28, 2019 716 92 28 36 May 20, 2023 #4 Ensure you have put the public IP address you get from Amazon in the sip and rtp address section in the variables. Otherwise it will bind to the internal address and Amazon won't use an ALG to fix it. Reactions: falk
