Getting incoming and outgoing call notifications
toolfolks
73
Posted in wrong category so re-posted here.
I need a notification when a an inbound or outbound call is made along with the caller ID.
I then need to pass this into our mobile app ( I'm looking at firebase at the moment but open to suggestions)
I'm looking through the database and see the v_xml_cdr table stores the call logs.
I can create a trigger on the insert record but unfortunately this is not inserted until the call is ended.
Is there any temp tables created anywhere when a call is made or received ? So I can create a trigger there.
What other options are available ?
Got an answer from Adrian Fretwell :
You should really start a separate thread for this but...
Look at the FreeSWITCH event socket:
https://freeswitch.org/confluence/display/FREESWITCH/mod_event_socket
Also look at event hooks, we use an event hook to drive a call centre wallboard, totally separate from FusionPBX:
https://freeswitch.org/confluence/display/FREESWITCH/Event+List
Off to fry my brain......
