Grandstream GXP16XX or GXP1610 auto provisioning phone admin password problem
TheMak
Hi, I have a 4.5.21 and succesfully provisionend a factory default resetted Grandstream gxp1610 but as soon as it reboots, I try to login with admin admin and it asks to change the default password; if I go ahead and try to change it it says that the default password I am using is not correct but it is admin admin.
Is there any know bug with Grandstream provisioning?
Thanks in advance
Regards
I haven’t looked at the particular template, but sounds like you don’t have “admin_password” set in default settings or the value is “admin”
aaah, yes that totally makes sense, I didn't even think about that I could change it with this section
I will go ahead with this try and let you know
