Grandstream provisioning
75
good morning
I have not been able to provision my grandstream gxv3140 hardphone, I have activated it in the default settings as follows:
And on the phone
I did not get the phone to download the settings can help me with this
I think if you are provisioning over HTTPS, you need a real secure certificate, try it over HTTP
I have tried with http and it does not work, I ask is it necessary to set option 120 in dhcp? Or I can test it initially by placing the parameters by hand on the device
Yes, you can put the options in the device manually, and no, if the provisioning address is in the phones you do not need a dhcp options
Sorry, but I have modified the configuration of the hardphone several times and I have not managed to get the configuration of the fusionpbx, you could guide me with a step by step of how to perform this operation
Good afternoon.
after taking a little time to take a coffee and relax I realized that I was doing things wrong so I started to start with the subject of provisioning and additionally understood that I must exhaust the greatest amount of resources before asking in the Forum, in order to achieve the approval of the phones only some details remain thanks for the help
