Group of domain settings
gpetrom
20
Hi
In default settings i am seeing the default settings per domain. I am able to override one by one setting.
Is there a way to have a group of domain settings and apply them to domains?
Thanks in advanced
Almost anything in "Default Settings" can be copied to a "Domain Setting" and changed to override the default.
If there is a set of commonly changed settings you wish to use between domains, you can copy the settings from one domain to another instead of searching out each setting every time in defaults.
