Group permissions help (solved)
Chidado
50
Helllo all,
I am have some problems with group permissions. I have created a new group and assigned permissions to be able to see Fax Server(all choices checked off). I also made changes to menu manager so that I can see the Fax Server menu.
The problem that I have is I cannot see any existing Fax servers and when I create a new Fax server I do not see it.
Any help is appreciated
I had not added any users to the fax server. Therefore could not see any fax server (existing or new). Once added all was good. Thanks to roger_roger in the irc channel.
