Help needed matching FreePBX extension vars to FusionPBX ext
Zebedee
Hi all,
I am using FreePBX bulk handler to export a CSV file of the extensions to then import into Fusion, however, as expected the variable names to not match.
So far I have matched the credentials and CID stuff but the issue is I cannot find the variables the Fusion uses to store voicemail infomation such as password and email address.
Sorry if this belongs in another thread.
Any pointers would be really appreciated!
Thanks in advance
-Z
There is an import for extensions and one for voicemail you need to use the one for voicemail for the voicemail settings.
I have followed through and done that, however it fails when I try to import using my best guess as what lines up to what. Is there a default required list of variables that voicemail requires that is causing it to fail due to it lacking something?
