Help renewing LetsEncrypt SSL
bobz
Hi all, I was curious if anyone could provide some help in the right direction. I received an email stating that my Letsencrypt ssl is expiring in a couple of days and went to try and renew it by running the ./letsencrypt.sh script but it didnt work. Email and domain name have been censored for privacy. Thank you in advance for any assistance.
root@fax:/usr/src/fusionpbx-install.sh/debian/resources# ./letsencrypt.sh
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
curl is already the newest version (7.88.1-10+deb12u5).
0 upgraded, 0 newly installed, 0 to remove and 29 not upgraded.
rm: cannot remove '/usr/local/sbin/dehydrated': No such file or directory
rm: cannot remove '/usr/src/dehydrated': No such file or directory
Domain Name: xx.xx.com
Email Address: xx@xx.com
Cloning into 'dehydrated'...
fatal: unable to access 'https://github.com/lukas2511/dehydrated.git/': Failed to connect to github.com port 443 after 135176 ms: Couldn't connect to server
./letsencrypt.sh: 30: cd: can't cd to /usr/src/dehydrated
cp: cannot stat 'dehydrated': No such file or directory
./letsencrypt.sh: 58: cd: can't cd to /usr/src/dehydrated
cp: cannot stat 'docs/examples/config': No such file or directory
./letsencrypt.sh: 68: ./dehydrated: not found
./letsencrypt.sh: 88: ./dehydrated: not found
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
2024/03/01 19:15:00 [notice] 122374#122374: signal process started
it shoulf renew automagically and you should not have to anything... given your initial install went smoothly
