help with dialplan condition based on agent
tjfayaz
15
Hi everyone, I have been trying with no success to find out how I can write a dialplan condition based on the agent field as shown in "sofia status profile internal reg". Basically I need to execute my script ONLY if the agent contains a specific string (in my case the string starts with iOS).
On top of this I also want it to execute this condition in the correct place so that I can delay the dialplan from ringing the agent for 2 seconds. I have not yet found the best place to put this using dialplan manager.
Any help or pointers would be much appreciated! Once I have cracked this I will be posting up a howto for IOS push notifications in fusionpbx.
for for example something like below
    <condition field="sofia_agent" expression="^([iOS])$">
        <action application="set" data="result=${system(/opt/push ${destination_number}@${domain_name} ${outbound_caller_id_number} ${outbound_caller_id_name})}"/>
        <action application="sleep" data="2000"/>
    </condition>
I'm not sure that sofia_agent is the right name to use, there is a channel variable called sip_user_agent.
Thanks Adrian, so now I have this, but it's where to put it! I tried putting it in the "local_extension" XML from dialplan manager but that does not work (it does not match so the condition is failing). If I remove the condition it works so I know my problem is the (a) the condition but also (b) where to put this so that it can delay the dialplan at the right point before ringing an extension.
    <condition field="${sip_user_agent}" expression="^([iOS])">
    </condition>
ok so I got it working, however I want to test the destination SIP user profile and there is no such variable! So basically I am going to have to think of a way to determine if the dialled extension is a particular agent based on the existing variables. In a basic way I could just say "any extension starting with an 8" is an iphone for example, but that's quite constraining.
I will work something out but in the meantime if any of you have any solutions or ideas please let me know?
