Hiding Callerid on the phone for incoming calls
djebali
42
Hi everybody
do someone to know how to hde the callerid of the callee when a call is ringing on the phone?
I thank you
sami
Prefix "*67" before the outbound number.
Go to Account > Dialplan and look up "call_privacy" with the search box.
He says specifically, INCOMING calls. Same should apply I think, set a privacy header on the inbound route.
Hello Mr DidgtialDaz, I really thank you
yes I need to hide the callerID for Incoming calls , is this possible in fpbx?
question: do you know to set "Resolved" to a post?
I thank you for your help and support
sami
sami
I'll try this , I need to hide the callerid for certain extension/user and visible to another , will it be possible?
Good Evening JamesBorn
I did found in the dialplan the "call_privacy" (please see in attachement the screenshot
question: I f I want to apply it for in inbound Destination
waht do I have to do exactly
in the second attachent you'l find the Destiation for the 0901232232
In waiting for your help I thank you
sami
I found and attached the inbound dialplan
please tell in the xml file where to put the "call_privacy" and wha to insert exactly
I thank you
sami
