How do I use multiple Gateways for Voice & Fax
shilohtech
I use Telnyx as my voice gateway and have it set to global. I would like to use T38fax as a fax gateway for ATAs that are connected as extensions. T38fax has a great tutorial on how to set up their service as a gateway in FusionPBX. But, I believe it is assumed that it will be the only gateway in their set-up scenario.
So, my question is how to make my fax ATA (fax) extensions use the T38fax trunk instead of the Telnyx (voice) trunk and how do I keep my phones from trying to outbound over the T38fax trunk?
Any insight would be appreciated, please keep in mind I am learning as I go.
