How does IVR exit sound work?
TurabG
77
I haven't seen this in the docs. I have set up an IVR which allows 2 max failures and then redirects the caller to the main queue. But I would like the user to hear the prompt "I am redirecting you to the operator" right after "That was an invalid entry". I thought "Exit sound" in the IVR settings should be for that purpose but it doesn't play that prompt whatever I choose as exit sound.
