How to block Anonymous inbound Calls
Ricky
16
I have followed these instructions:
Configuration
Call Block works by checking the incoming callerid number against its database. If the callerid number and domain match, then the call can be blocked depending on the options that you set for that number.
For a particular Incoming Route (in Dailplan/Incoming Routes menu):
  • Add an Action (bottom of Incoming dialplan page)
  • set Tag=Action
  • set Order=70 (some number such that the action is performed before the Transfer action)
  • set Type=lua
  • Set Data=call_block.lua C
  • Group can be left empty
  • Click Save
The result should be a line in the incoming dialplan that looks like:
  • 'action lua call_block.lua C 70' just above the 'action transfer' line
Usage
Call Block appears on the Apps list. To manage your list of Blocked callers click on Apps/Call Block.. This shows you the current list of callerids.
To add:
  • Click on the + sign
  • Select one of the recent callers (click on + sign at RH side of page) to add it to the list OR
  • Manually enter the required information at the bottom of the page
  • Set the Action that you want to occur for that caller
  • Enable the action and click Save
with no luck. Has anyone solved this issue. Thanks
I think what @jsteel means is that the post title was "How to block Anonymous inbound Calls" but then you were doing something with the call blocking module that seems totally unrelated.
