How to renew Letsencrypt
Win
This might be a stupid question, but I really don't know how to renew Letsencrypt since I installed Letsencrypt from the source that I got from
/usr/src/fusionpbx-install.sh/debian/resources#
usually I use certbot-auto renew but now I didn't find certbot-auto in FusionPBX installer package.
need advice
thank you
Hi Win,
I'm having similar issues as well. It seems that the instructions from the site: https://docs.fusionpbx.com/en/latest/getting_started/lets_encrypt.html are no longer valid, at least with multi-domain. Not sure if you found some different instructions out there or not, but have been looking into this all day. On a webserver using nginx, I do have a cronjob running: '/usr/bin/certbot renew >> /var/log/le-renew.log' daily to do the renewals. not sure if that will help out or not.
Regards,
Gordon S.
Thanks @Gordon, I have fixed it by manually install certbot and create its cronjob.
Good day!
