How to set variable from IVR Menu?
JoyceBabu
I want to present a language selection menu, and set a variable depending on the option pressed by the caller. How can I do this from IVR Menu?
I tried entering
menu-exec-app:set ivrs_lang=1
But the value is lost on clicking save.
Thank you @DigitalDaz for re-opening the thread. There was an error in the command that I shared earlier. The app should be checked out to /var/www/fusionpbx/app. The correct command is
cd /var/www/fusionpbx/app && git clone https://github.com/fusionpbx/fusionpbx-app-dialplan_tools dialplan_tools
