L leean New Member Apr 11, 2019 17 1 3 53 vietvan.net May 15, 2022 #1 Hello , i wonder if the freeswitch support the tap in active calls from FS_CLI ? If yes then how to do that Thank you
A agree Member Aug 26, 2018 140 24 18 May 16, 2022 #2 checkout https://freeswitch.org/confluence/display/FREESWITCH/mod_dptools:+eavesdrop In fusion it's *33 followed by the extension to tap into
L leean New Member Apr 11, 2019 17 1 3 53 vietvan.net May 18, 2022 #3 OK, done with default config on dialplan manager one more question: how do we install the mod_spy when it is not installed by default we try the apt-get update && apt-get install freeswitch-mod-spy --fix-missing but it says Unable to locate package freeswitch-mod-spy thank you
A agree Member Aug 26, 2018 140 24 18 May 18, 2022 #4 mod_spy is not a maintained module I wouldn't recommend it Reactions: leean
