Inbound Calls - One Side Audio !
xserver
Hi Everyone ,
I am on a fresh fusionbox setup and i am a bit confused on how to make the sip profiles for internal and external. I read the docs and it mentioned that the external profile should listen on 5080 and internal on 5060 but i am confused which IP to use for internal and external profiles as i have 3 IP on FusionBox.
SIP Provider (10.229.56.20) ---- Routed ------- FusionBox Provider Side (10.229.55.217) -------- FusionBox Client Side (10.128.0.1) ------- IP Phone (10.130.1.15)
FusionBox Management Public IP ( XXX.XXX.X.X)
In above scenario, i have 1 way audio in incoming calls from SIP provider , Outgoing calls are good.
  1. freeswitch@zsip> sofia status profile ZAP_LOCAL_PROFILE
  2. =================================================================================================
  3. Name ZAP_LOCAL_PROFILE
  4. Domain Name N/A
  5. Auto-NAT false
  6. DBName sofia_reg_ZAP_LOCAL_PROFILE
  7. Pres Hosts 10.128.0.1,10.128.0.1
  8. Dialplan XML
  9. Context default
  10. Challenge Realm auto_from
  11. RTP-IP 10.128.0.1 (LAN1 IP Connected to IP Phones)
  12. Ext-RTP-IP 10.128.0.1
  13. SIP-IP 10.128.0.1
  14. Ext-SIP-IP 10.128.0.1
  15. URL sip:mod_sofia@10.128.0.1:5060
  16. BIND-URL sip:mod_sofia@10.128.0.1:5060;maddr=10.128.0.1;transport=udp,tcp
  17. HOLD-MUSIC local_stream://moh
  18. OUTBOUND-PROXY N/A
  19. CODECS IN PCMU,PCMA,G729
  20. CODECS OUT PCMU,PCMA,G729
  21. TEL-EVENT 101
  22. DTMF-MODE rfc2833
  23. CNG 13
  24. SESSION-TO 0
  25. MAX-DIALOG 0
  26. MAX-RECV-RPS 1000
  27. NOMEDIA false
  28. LATE-NEG false
  29. PROXY-MEDIA false
  30. ZRTP-PASSTHRU false
  31. AGGRESSIVENAT false
  32. CALLS-IN 6
  33. FAILED-CALLS-IN 2
  34. CALLS-OUT 1
  35. FAILED-CALLS-OUT 0
  36. REGISTRATIONS 122
  37. freeswitch@zsip> sofia status profile EXTERNAL_PROFILE
  38. =================================================================================================
  39. Name VODA_EXT_PROFILE
  40. Domain Name N/A
  41. Auto-NAT false
  42. DBName sofia_reg_EXTERNAL_PROFILE
  43. Pres Hosts
  44. Dialplan XML
  45. Context public
  46. Challenge Realm auto_to
  47. RTP-IP 10.229.55.217 (LAN2 IP Connected to SIP Provider)
  48. Ext-RTP-IP 10.229.55.217
  49. SIP-IP 10.229.55.217
  50. Ext-SIP-IP 10.229.55.217
  51. URL sip:mod_sofia@10.229.55.217:5060
  52. BIND-URL sip:mod_sofia@10.229.55.217:5060;transport=udp,tcp
  53. HOLD-MUSIC N/A
  54. OUTBOUND-PROXY N/A
  55. CODECS IN PCMU,PCMA,G729
  56. CODECS OUT PCMU,PCMA,G729
  57. TEL-EVENT 101
  58. DTMF-MODE rfc2833
  59. CNG 13
  60. SESSION-TO 0
  61. MAX-DIALOG 0
  62. MAX-RECV-RPS 1000
  63. NOMEDIA false
  64. LATE-NEG false
  65. PROXY-MEDIA false
  66. ZRTP-PASSTHRU false
  67. AGGRESSIVENAT false
  68. CALLS-IN 1
  69. FAILED-CALLS-IN 0
  70. CALLS-OUT 3
  71. FAILED-CALLS-OUT 2
  72. REGISTRATIONS 0
Any helpful pointers will be highly appreciated .
