Hi everyone,
Hope you guys are doing great.
I am trying to setup an inbound dial plan that can detect if the extension exists (on Extensions).
And if not, to route the call to a voicemail system.
That is for example in case an employee leaves the company. While the number still exists on the Sip provider (SignalWire), the extension in FusionPBX would be removed. And we want to make sure this call goes to the global voicemail or some sort of IVR.
For exampling purpose, below is what I tried to do.. (which I thought would be the easy way)
I created two dial plans with different order, and set the "inbound_calls" dial plan as TRUE to continue.
However, looks like go_to_voicemail dial plan is not being executed.
Below is my Go_to_voicemail dial plan:
PS: If I set Go_to_voicemail order <100, it works the way it should. (call goes to the voicemail). However, of course, all calls go to voicemail.
Any ideas?
Thanks and Merry Christmas!
Alan
Any ideas?
Alan
