inbound works, outbound no, please help!
calin
hi all, just installed a fusionpbx on a vm with public ip and want now to use it as multitenant. so far so good, inbound works on tenants, i'm using ip trunks from zadarma, but i can't figure how outbound works, as i receive everytime "internal server error"..... i don't no what to do.... please help....
now i receive "disconnected, not found: 'dialled number'" on sngrep i got no route destination?!?!?!
why did i have 2 routes in outbound routes? because in every tutorials i see only one....
you need to create outbound route in whichever format your upstream provider is accepting the call.
yes, created in dialplan menu, but after finished to create i see in "outbound routes" 2 rules and i don't know why
hmmmmm,
somehow now outbound works and inbound no....
attached log from fs_cli:
2022-08-05 15:34:08.963350 74.00% [NOTICE] switch_channel.c:1123 New Channel sofia/external/+40727191939@sip.zadarma.com [0ca49082-14d4-11ed-9836-9f1656192be6]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_NEW (Cur 1 Tot 65)
2022-08-05 15:34:08.963350 74.00% [INFO] sofia.c:10462 sofia/external/+40727191939@sip.zadarma.com receiving invite from 185.45.152.161:5060 version: 1.10.7 -release 64bit call-id: 70f5e3d67ebb7b4b18353df97daaece5@37.139.38.35:5060
2022-08-05 15:34:08.963350 74.00% [DEBUG] sofia.c:10556 verifying acl "domains" for ip/port 185.45.152.161:0.
2022-08-05 15:34:08.963350 74.00% [DEBUG] sofia.c:10585 IP 185.45.152.161 Approved by acl "domains[]". Access Granted.
2022-08-05 15:34:08.963350 74.00% [DEBUG] sofia.c:7499 Channel sofia/external/+40727191939@sip.zadarma.com entering state [received][100]
2022-08-05 15:34:08.963350 74.00% [DEBUG] sofia.c:7509 Remote SDP:
v=0
o=root 1633718525 1633718525 IN IP4 37.139.38.35
s=Zadarma Voip
c=IN IP4 37.139.38.35
t=0 0
m=audio 18350 RTP/AVP 8 0 18 110 117 119 3 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:110 speex/8000
a=rtpmap:117 speex/16000
a=rtpmap:119 speex/32000
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:60
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5705 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5705 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:110:8000:20:0:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:110:8000:20:0:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:110:8000:20:0:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:117:16000:20:0:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:117:16000:20:0:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:117:16000:20:0:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:119:32000:20:0:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:119:32000:20:0:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:119:32000:20:0:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [GSM:3:8000:20:13200:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [GSM:3:8000:20:13200:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [GSM:3:8000:20:13200:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5566 Set telephone-event payload to 101@8000
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:3870 Set Codec sofia/external/+40727191939@sip.zadarma.com PCMA/8000 20 ms 160 samples 64000 bits 1 channels
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_codec.c:111 sofia/external/+40727191939@sip.zadarma.com Original read codec set to PCMA:8
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5915 Set telephone-event payload to 101@8000
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_media.c:5973 sofia/external/+40727191939@sip.zadarma.com Set 2833 dtmf send payload to 101 recv payload to 101
2022-08-05 15:34:08.963350 74.00% [DEBUG] sofia.c:7933 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_NEW -> CS_INIT
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:600 (sofia/external/+40727191939@sip.zadarma.com) State NEW
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_INIT (Cur 1 Tot 65)
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:624 (sofia/external/+40727191939@sip.zadarma.com) State INIT
2022-08-05 15:34:08.963350 74.00% [DEBUG] mod_sofia.c:97 sofia/external/+40727191939@sip.zadarma.com SOFIA INIT
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:40 sofia/external/+40727191939@sip.zadarma.com Standard INIT
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:48 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_INIT -> CS_ROUTING
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:624 (sofia/external/+40727191939@sip.zadarma.com) State INIT going to sleep
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_ROUTING (Cur 1 Tot 65)
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_channel.c:2380 (sofia/external/+40727191939@sip.zadarma.com) Callstate Change DOWN -> RINGING
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:640 (sofia/external/+40727191939@sip.zadarma.com) State ROUTING
2022-08-05 15:34:08.963350 74.00% [DEBUG] mod_sofia.c:158 sofia/external/+40727191939@sip.zadarma.com SOFIA ROUTING
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:230 sofia/external/+40727191939@sip.zadarma.com Standard ROUTING
2022-08-05 15:34:08.963350 74.00% [INFO] mod_dialplan_xml.c:639 Processing +40727191939 <+40727191939>->421641 in context public
Dialplan: sofia/external/+40727191939@sip.zadarma.com parsing [public->+40312297420] continue=false
Dialplan: sofia/external/+40727191939@sip.zadarma.com Regex (FAIL) [+40312297420] destination_number(421641) =~ /^\+(40312297420)$/ break=on-false
2022-08-05 15:34:08.963350 74.00% [INFO] switch_core_state_machine.c:306 No Route, Aborting
2022-08-05 15:34:08.963350 74.00% [NOTICE] switch_core_state_machine.c:307 Hangup sofia/external/+40727191939@sip.zadarma.com [CS_ROUTING] [NO_ROUTE_DESTINATION]
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:640 (sofia/external/+40727191939@sip.zadarma.com) State ROUTING going to sleep
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_HANGUP (Cur 1 Tot 65)
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:844 (sofia/external/+40727191939@sip.zadarma.com) Callstate Change RINGING -> HANGUP
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:846 (sofia/external/+40727191939@sip.zadarma.com) State HANGUP
2022-08-05 15:34:08.963350 74.00% [DEBUG] mod_sofia.c:468 Channel sofia/external/+40727191939@sip.zadarma.com hanging up, cause: NO_ROUTE_DESTINATION
2022-08-05 15:34:08.963350 74.00% [DEBUG] mod_sofia.c:613 Responding to INVITE with: 404
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:59 sofia/external/+40727191939@sip.zadarma.com Standard HANGUP, cause: NO_ROUTE_DESTINATION
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:846 (sofia/external/+40727191939@sip.zadarma.com) State HANGUP going to sleep
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:616 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_HANGUP -> CS_REPORTING
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_REPORTING (Cur 1 Tot 65)
2022-08-05 15:34:08.963350 74.00% [DEBUG] switch_core_state_machine.c:932 (sofia/external/+40727191939@sip.zadarma.com) State REPORTING
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_state_machine.c:168 sofia/external/+40727191939@sip.zadarma.com Standard REPORTING, cause: NO_ROUTE_DESTINATION
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_state_machine.c:932 (sofia/external/+40727191939@sip.zadarma.com) State REPORTING going to sleep
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_state_machine.c:607 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_REPORTING -> CS_DESTROY
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_session.c:1753 Session 65 (sofia/external/+40727191939@sip.zadarma.com) Locked, Waiting on external entities
2022-08-05 15:34:09.123354 74.00% [NOTICE] switch_core_session.c:1771 Session 65 (sofia/external/+40727191939@sip.zadarma.com) Ended
2022-08-05 15:34:09.123354 74.00% [NOTICE] switch_core_session.c:1775 Close Channel sofia/external/+40727191939@sip.zadarma.com [CS_DESTROY]
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_state_machine.c:735 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_DESTROY (Cur 0 Tot 65)
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_state_machine.c:745 (sofia/external/+40727191939@sip.zadarma.com) State DESTROY
2022-08-05 15:34:09.123354 74.00% [DEBUG] mod_sofia.c:379 sofia/external/+40727191939@sip.zadarma.com SOFIA DESTROY
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_state_machine.c:175 sofia/external/+40727191939@sip.zadarma.com Standard DESTROY
2022-08-05 15:34:09.123354 74.00% [DEBUG] switch_core_state_machine.c:745 (sofia/external/+40727191939@sip.zadarma.com) State DESTROY going to sleep
2022-08-05 15:34:09.663343 73.77% [NOTICE] switch_channel.c:1123 New Channel sofia/external/+40727191939@sip.zadarma.com [0d10c1bc-14d4-11ed-9838-9f1656192be6]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_NEW (Cur 1 Tot 66)
2022-08-05 15:34:09.663343 73.77% [INFO] sofia.c:10462 sofia/external/+40727191939@sip.zadarma.com receiving invite from 185.45.152.161:5060 version: 1.10.7 -release 64bit call-id: 3b5cfcb93cab982d37234f293f735900@37.139.38.35:5060
2022-08-05 15:34:09.663343 73.77% [DEBUG] sofia.c:10556 verifying acl "domains" for ip/port 185.45.152.161:0.
2022-08-05 15:34:09.663343 73.77% [DEBUG] sofia.c:10585 IP 185.45.152.161 Approved by acl "domains[]". Access Granted.
2022-08-05 15:34:09.663343 73.77% [DEBUG] sofia.c:7499 Channel sofia/external/+40727191939@sip.zadarma.com entering state [received][100]
2022-08-05 15:34:09.663343 73.77% [DEBUG] sofia.c:7509 Remote SDP:
v=0
o=root 1258572795 1258572795 IN IP4 37.139.38.35
s=Zadarma Voip
t=0 0
m=audio 11224 RTP/AVP 8 0 18 110 117 119 3 101
a=fmtp:18 annexb=no
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:60
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5705 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5705 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:110:8000:20:0:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:110:8000:20:0:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:110:8000:20:0:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:117:16000:20:0:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:117:16000:20:0:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:117:16000:20:0:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:119:32000:20:0:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:119:32000:20:0:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [speex:119:32000:20:0:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [GSM:3:8000:20:13200:1]/[G722:9:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [GSM:3:8000:20:13200:1]/[PCMU:0:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5650 Audio Codec Compare [GSM:3:8000:20:13200:1]/[PCMA:8:8000:20:64000:1]
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5566 Set telephone-event payload to 101@8000
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:3870 Set Codec sofia/external/+40727191939@sip.zadarma.com PCMA/8000 20 ms 160 samples 64000 bits 1 channels
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_codec.c:111 sofia/external/+40727191939@sip.zadarma.com Original read codec set to PCMA:8
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5915 Set telephone-event payload to 101@8000
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_media.c:5973 sofia/external/+40727191939@sip.zadarma.com Set 2833 dtmf send payload to 101 recv payload to 101
2022-08-05 15:34:09.663343 73.77% [DEBUG] sofia.c:7933 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_NEW -> CS_INIT
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:600 (sofia/external/+40727191939@sip.zadarma.com) State NEW
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_INIT (Cur 1 Tot 66)
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:624 (sofia/external/+40727191939@sip.zadarma.com) State INIT
2022-08-05 15:34:09.663343 73.77% [DEBUG] mod_sofia.c:97 sofia/external/+40727191939@sip.zadarma.com SOFIA INIT
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:40 sofia/external/+40727191939@sip.zadarma.com Standard INIT
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:48 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_INIT -> CS_ROUTING
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:624 (sofia/external/+40727191939@sip.zadarma.com) State INIT going to sleep
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_ROUTING (Cur 1 Tot 66)
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_channel.c:2380 (sofia/external/+40727191939@sip.zadarma.com) Callstate Change DOWN -> RINGING
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:640 (sofia/external/+40727191939@sip.zadarma.com) State ROUTING
2022-08-05 15:34:09.663343 73.77% [DEBUG] mod_sofia.c:158 sofia/external/+40727191939@sip.zadarma.com SOFIA ROUTING
2022-08-05 15:34:09.663343 73.77% [DEBUG] switch_core_state_machine.c:230 sofia/external/+40727191939@sip.zadarma.com Standard ROUTING
2022-08-05 15:34:09.663343 73.77% [INFO] mod_dialplan_xml.c:639 Processing +40727191939 <+40727191939>->421641 in context public
2022-08-05 15:34:09.663343 73.77% [INFO] switch_core_state_machine.c:306 No Route, Aborting
2022-08-05 15:34:09.663343 73.77% [NOTICE] switch_core_state_machine.c:307 Hangup sofia/external/+40727191939@sip.zadarma.com [CS_ROUTING] [NO_ROUTE_DESTINATION]
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:640 (sofia/external/+40727191939@sip.zadarma.com) State ROUTING going to sleep
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_HANGUP (Cur 1 Tot 66)
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:844 (sofia/external/+40727191939@sip.zadarma.com) Callstate Change RINGING -> HANGUP
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:846 (sofia/external/+40727191939@sip.zadarma.com) State HANGUP
2022-08-05 15:34:09.683377 73.77% [DEBUG] mod_sofia.c:468 Channel sofia/external/+40727191939@sip.zadarma.com hanging up, cause: NO_ROUTE_DESTINATION
2022-08-05 15:34:09.683377 73.77% [DEBUG] mod_sofia.c:613 Responding to INVITE with: 404
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:59 sofia/external/+40727191939@sip.zadarma.com Standard HANGUP, cause: NO_ROUTE_DESTINATION
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:846 (sofia/external/+40727191939@sip.zadarma.com) State HANGUP going to sleep
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:616 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_HANGUP -> CS_REPORTING
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:581 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_REPORTING (Cur 1 Tot 66)
2022-08-05 15:34:09.683377 73.77% [DEBUG] switch_core_state_machine.c:932 (sofia/external/+40727191939@sip.zadarma.com) State REPORTING
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_state_machine.c:168 sofia/external/+40727191939@sip.zadarma.com Standard REPORTING, cause: NO_ROUTE_DESTINATION
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_state_machine.c:932 (sofia/external/+40727191939@sip.zadarma.com) State REPORTING going to sleep
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_state_machine.c:607 (sofia/external/+40727191939@sip.zadarma.com) State Change CS_REPORTING -> CS_DESTROY
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_session.c:1753 Session 66 (sofia/external/+40727191939@sip.zadarma.com) Locked, Waiting on external entities
2022-08-05 15:34:09.843395 73.77% [NOTICE] switch_core_session.c:1771 Session 66 (sofia/external/+40727191939@sip.zadarma.com) Ended
2022-08-05 15:34:09.843395 73.77% [NOTICE] switch_core_session.c:1775 Close Channel sofia/external/+40727191939@sip.zadarma.com [CS_DESTROY]
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_state_machine.c:735 (sofia/external/+40727191939@sip.zadarma.com) Running State Change CS_DESTROY (Cur 0 Tot 66)
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_state_machine.c:745 (sofia/external/+40727191939@sip.zadarma.com) State DESTROY
2022-08-05 15:34:09.843395 73.77% [DEBUG] mod_sofia.c:379 sofia/external/+40727191939@sip.zadarma.com SOFIA DESTROY
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_state_machine.c:175 sofia/external/+40727191939@sip.zadarma.com Standard DESTROY
2022-08-05 15:34:09.843395 73.77% [DEBUG] switch_core_state_machine.c:745 (sofia/external/+40727191939@sip.zadarma.com) State DESTROY going to sleep
