Issue Adjusting To Dynamic External IP
legolas108
12
Winter, WI
www.wintergreenhouse.com
Adjusting to a dynamically changing external IP (ADSL) by maintaining a dynamically adjusted DNS entry works, but the system remains unavailable until DNS change takes effect (at least 15-20 minutes even when setting the TTL to 5 minutes).
So, tried to maintain the IP directly with our VoIP provider and in FusionPBX 4.5.10 / FreeSwitch 1.8.4. Our VoIP provider offers a REST interface to update the IP for the Origination URIs, so no issue there. For FP/FS tried to update the external profile's ext-sip-ip and ext-rtp-ip variables directly in the PostgreSQL database fusionpbx:
root@pbx:~# su - postgres -c $"/usr/bin/psql -d fusionpbx -c \"update v_sip_profile_settings sps set sip_profile_setting_value = 'autonat:12.34.56.78' from v_sip_profiles sp where (sps.sip_profile_uuid = sp.sip_profile_uuid) and (sp.sip_profile_name = 'external') and (sps.sip_profile_setting_name in ('ext-sip-ip', 'ext-rtp-ip'));\""
and issuing
root@pbx:~# /usr/bin/fs_cli -x "sofia profile external restart"
root@pbx:~# /usr/bin/fs_cli -x "xml_flush_cache"
afterwards.
When changing these two variables via FusionPBX GUI, Advanced / SIP Profiles / external, the system immediately continues to work normally, but when updating from the command line there's e.g. one-way audio (callee doesn't hear caller).
So, what more commands are needed to make the IP change take effect properly?
Thanks much for any help!
