Issue login to Admin Portal
kwangmien
59
I installed Fusion PBX for Centos 7 using the URL
https://www.fusionpbx.com/download
After installation, I tried to login using 'admin' and the password given. However, the result is "Invalid Username and Password".
I tried to reset the password using the below steps
cd /etc/fusionpbx
mv config.php config1.php
and then access my Fusion PBX by entering http://ipaddress
However, when https://ipaddress/core/install/install.php is accessed, the result is a blank page.
Can anyone advise how I can reset the password using command line in Centos 7 ?
Thank you.
Regards,
Kwang Mien
When you completed the install it would have given you the password. user name is admin@192.168.1.1 (insert local ip address of your box)
Your going to have issues with gateways regardless of if you get it going. I lost a month going down the Centos path. Blown it out and go Debian 9.
Tim
