IVR confirm-macro confirm-key
aunghtain
Can anyone give an example of how to use confirm-macro and confirm-key? According to freeswitch 1.2 book, confirm-macro specifies which Phrase Macro to play while waiting for the confirm-key to be pressed. When set, the macro is played after the caller enters a destination extension number at the IVR. But it does not seem to be working.
What I would like to do is that I want to confirm the menu option the customer selects before processing the menu. For example, you selected "1", if this is correct, press "*" to connect to sale. otherwise, press '#' to go back to main menu.
Thanks!
